Results 1 to 7 of 7
Thread: Great Site for code test and fault issues!!!!hope it helps people
    VY SV8 HBD---mmmm LS1
    Simon Champion! On The Volley Champion! Shootin Hoops Champion! Batting Champ Champion!
    Dec 2005
    Western Suburbs
    Default Great Site for code test and fault issues!!!!hope it helps people
    found this site seems pretty good might have helped me save sum cash by not sending it 2 the mechanics i found out that problem might have only been a 5 buck sensor mechanics wood have made it sound way worse then wat it is not 2 mention 40 bucks labour an hour hope it helps guys
    http://www.users.on.net/~nweber/comm...ech/index.html
    VRII Acclaim
    Jul 2005
    The site is ok, but nothing compared to here. There is nothing there that we havnt covered. Having a quick read, I did notice a few comments that werent accurate. ie "When the wire gets a chance to cool down all of a sudden the charge that is stored in the alternator and the wire will get through to the battery". The alternator can store charge in the form of a magnetic field, but its really nothing. Certinally not enough to charge a battery.
    "The basic problem is that the pins should be gold plated to prevent corrosion but they aren't to cut 10c off the production price for Holden. The WD makes an oil film to keep oxygen out."
    Thats a load of crap. The pins dont need to be gold plated at all, I dont recommend WD40 on electrical connections, contact cleaner is a much better option, and there is nothing wrong with oxygen on those connectors.
    Dec 2005
    Western Suburbs
    VRII Acclaim
    Jul 2005
    http://justcommodores.com.au/
    I spose this site is alright, the fella has put alot of work into it, does list all the models, although not a great detail on repairs. http://au.geocities.com/commodoretech/modelfaults.html
    Dec 2005
    Western Suburbs
    Got results codes are 41,42,47,49 sum of them might be my battery though not 2 sure as its full of acid and **** so il clean it and check it again 2moz
    can anyone let me no wat the codes mean VR-calais_series 1
    41,42,47,49
    VRII Acclaim
    Jul 2005
    47 is the notorious CAS problem. Doesnt sound like the temp sensor in the alternator anymore. I will go into more detail in your other post.
    Dec 2005
    Western Suburbs
    hahaha after doin and standy last night my car seems 2 be running smooth no rough idle nuthing
    hmmmm have 2 wait and c
  1. GREAT Site for diagnostic codes
    By gr8304_87 in forum General
    Last Post: 30-04-2006, 12:03 PM
  2. Great site for WA
    By Z()LTAN in forum General Discussion
    Last Post: 22-12-2005, 09:01 PM
  3. Need A Name For My Test Site
    By The1985divo in forum The Pub
    Last Post: 27-05-2004, 09:37 PM
