Results 1 to 3 of 3
Thread: Rear Main Seal
    Slow VR's Avatar
    Slow VR is offline Another White Crummodore
    VR Series II
    Apr 2006
    Cairns, Nth Qld
    Default Rear Main Seal
    Ok, im gunna wind up replacing my Auto at some stage soon, ive noticed there is an oil leak from the rear of the engine. Ive already replaced the valley cover gaskets and rocker cover gaskets. Its not power steering fluid or auto fluid. Its engine oil.
    So are there any tricks in replacing the rear main seal once ive got my box out?
    Jumping Commodores is the right thing to do... Flex is a good thing.
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    yeh see if you can borrow the proper aligning tools form holden otherwise you will probably make an even bigger leak from misalignment.....holden has revised their rear main seal and flipped it round the other way. it needs to be pressed out so the housing can be aligned and then fitted back in after the housing and sump is aligned
    Slow VR's Avatar
    VR Series II
    Apr 2006
    Cairns, Nth Qld
    So in other words.... deal with the leak.... I highly doubt a dealership will lend out tools to a stranger.... Have they changed the new replacement rear main seal?
  1. vn s1 rear main seal
    By shyvn6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2006, 07:28 PM
  2. Rear main seal in VN 5lt
    By vnberlwagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-03-2006, 08:46 PM
  3. What rear main seal to use in hot 253
    By Mattie77 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-10-2005, 05:20 PM
  4. VR Rear main seal
    By Ute 94 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2005, 09:47 PM
  5. Rear main seal on 5 ltr
    By vsv8berlinawag in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-08-2005, 10:19 PM
