Results 1 to 24 of 24
Thread: my super super low front springs
    '97 VS Commodore + '98 E36
    Apr 2005
    Question my super super low front springs
    aye fellas,
    i recieved my front super-super-low springs today and just asking if this is the right code for my, VS 1997 commodore sedan.
    code: KHFL-22 SSL
    because i sat it in my new struts for the front, and when it sits in place it doesnt sit straight? or will fit sit properly once i put the spring seat and such 2g4? i havent assembled the whole strut, i just placed the spring in the strut.
    97 VS Series 2
    Apr 2005
    QLD
    I Have KHFL-47SSL and when they sit in the strut i know what u mean, they seem to be too small in diameter.
    Your spring is used as an ultra low for VB-VP where as mine is used as a SSL for a VR and as SL for a VS (thats what kings springs told me when I emailed them)
    Apr 2005
    oh rats...
    so umm whats the hapz?? can i still use these springs that i have??
    VS Exec Series II
    Jan 2005
    Ringwood, VIC
    hey mate...
    ive got a 97 vs series II exec...the superlows ive got in the front are KHFL-47SSL, so looks like your gonna hafta change the ones that you have. and as for struts, i'm assuming u've got monro gt gas struts..the codes should be 35-3425 and 35-3424.
    If your unsure about the spring codes just check out the king springs website, they have a table with all the codes for springs and what models they suit.
    Apr 2005
    Default whats going on??
    ive got new struts for my new springs
    the new struts are
    http://cgi.ebay.com.au/ws/eBayISAPI....4577&rd=1&rd=1
    and as for the springs another bloke gave me KHFL-22 SL which are said to be for VB-VP according to jon z and kingsrpings
    and i specifically told the bloke that my car is a 97 VS.
    but he tells me that they will fit??
    IS THIS TRUE?
    the pix attached are as shown when i placed the springs in. will it sit straight once i put the top plate and such on?
    his email:
    The springs are the same design between the 47 and 22 series. You requested ahub to guard measurement. You said you have 14.2 inches in the front, and want to lower the car by 2 inches. This will give a hub to guard of 12.2 inches, or 300mm, so i sent you the springs you asked for. If you knew you wanted 47ssl why didn't you ask for it. The springs will fit, and i have sold you what you asked for. What more would you like ???
    Attached Thumbnails Attached Thumbnails my super super low front springs-justcommo.jpg
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    I'm 90% sure they'll fit. and yeah the springs do sit a bit funny when they're not trapped in. when you fit the bearing/support and bearing plate they'll sit right. do youself a favour and replace the bearings, bearing supports and bump stops at the same time.
    when you fit the springs, make sure the letters and numbers are the right way up, as this affects the way the spring sits on the strut
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
    Apr 2005
    oh righteo then, yea when i bought the new struts they chucked in new turn bearings, top mount thengo and bump stops aswell =D
    so this is normal position when they are not captive??
    in the second pic will the bottom coil sink in to the strut once i assemble everything together??
    VR EXEC
    Dec 2005
    quarantine
    bonus!
    yes
    well... you gotta get rid of that black thing between the spring and seat or it'll get crushed
    VR EXEC
    Dec 2005
    quarantine
    oh, and I'll add in here, DON'T BUY NOLATHANE! they will crack or crumble within a few shirt months and need replacing again. go superpro
    Apr 2005
    no nolathane aye???..thats good cause they supplied me with all ultima suspension components.
    VR EXEC
    Dec 2005
    quarantine
    never heard of ultima... I think you misunbderstood my nolathane comment, they make bushes, trailing arms etc, not struts. but they're ****. they crumble and squeek. noltec are the other brand I couldn't think of.
    anyways, got an electrical storm brewing so I gotta switch off now. if you got any more hassles or questions, PM me if ya want
    Apr 2005
    na na i understood clearly what ya meant about the nolathane bushes. they supplied me with sway bar link pin kits aswell including with bushes not sure what brand they are but the bushes are blue in color i thenk the brand is 'wasp' from auto-1?
    but yea i hear bad feed back about nolathane aswell
    thankz
    97 VS Series 2
    Apr 2005
    QLD
    also be careful when u locate the top bearing sin the rubber bushes up top. Pedders installed my front for me and they managed to crush the RH top bearing!
    They were a bit embarrassed when went back that day, was a bit annoying that they couldn't get it right.
    Apr 2005
    would it be necesassary to compress the spring first and then place the top mounts and bolt it up?
  15. #15
    97 VS Series 2
    Apr 2005
    QLD
  16. #16
    VR EXEC
    Dec 2005
    quarantine
    Quote Originally Posted by r_i_d_a_h View Post
    thankz
    wasp don't look too bad, seen them on ebay, pretty sure they use noltec bushes. yeah you'll need spring compresors, mine cost about $20 from ricerbarn. and like jon said, be careful with the bearings, they're easy to crush, and break if you drop them. plus they need to be fitted round side up
  17. #17
    VX SS M6
    Jun 2005
    that part number for a VS is super low i got the same, make sure you get ultra lows in the rear
  18. #18
    Apr 2005
    ahhhh so VS berlina, your front springs are KHFL-22 SSL is that what your telling me?
  19. #19
    vu ss
    Apr 2006
    mate if it helps i got superlows off ebay 12mnths ago,code on box is khfl 47ssl. no problems fitting them,although i paid to have the front done and i should have got ultras in thr rear,it sat like a 1974 HQ. i cut 1 coil off the rear to level it out,one day ill buy a rear set of ultras.......
  20. #20
    VX SS M6
    Jun 2005
    actuly i had a proper look on the kings catalogue and those springs are ultra lows for vb-vp mine are the khfl 47ssl, so i guess you already know that. but it says that the khfl 47ssl is the lowest front spring they make.
  21. #21
    Apr 2005
    is there any significant diferenece between the vb-vp and vr-vs front struts, not the front shocks but the autuall strut?..like the autually parts dat holds the springs
    and what do those numbers '22' '47' mean?...
  22. #22
    VR EXEC
    Dec 2005
    quarantine
    VN/VP have a sleeve for the clevis rather than it being welded on like VR onward. no idea about the number
  23. #23
    97 VS Series 2
    Apr 2005
    QLD
    not too sure about the numbers, email king springs they usually get back to you pretty quick.
  24. #24
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    just to clarify, nolathane dont "crack and crumble" unless its a bush that is supposed to be greased and isnt, nolathane throw in a bag of grease with any bush that needs it and says in the instructions TO grease them.
    ive got nolathane adjustable strut tops, been in the car on ultras for over 18 months and not one problem, except they lift the height by about 2cm, as will all urethane/non rubber strut tops.
    ive also got nolathane bushes in several other parts in the car, and not one problem yet
  1. Super low Springs
    By grinfked_limo in forum Parts And Other Items For Sale
    Last Post: 05-09-2007, 10:42 AM
  2. Super Super Super Low springs NOT LOW!
    By brenz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-11-2006, 07:58 PM
  3. super low springs
    By vq rat in forum Parts And Other Items For Sale
    Last Post: 05-10-2006, 09:58 PM
  4. wtb super low king springs
    By lowrida56 in forum Swap / Wanted to Buy / Trade
    Last Post: 06-11-2005, 02:28 AM
  5. looking for pics of superlows and super super lows in a vn
    By lowrida56 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-10-2005, 10:41 PM
