Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: speedo not working
    MiSs MeOw's Avatar
    MiSs MeOw is offline MiSs MeOw
    spankin 1998 VT
    Feb 2007
    Default speedo not working
    hey guys um i just brought my 1993 VR commodore and i noticed that the speedo isnt working, the temp gauge, tacho and fuel ones are working just the speedo isnt, either is the odometre
    it was working at times like it was wanting to work but just drops out
    could it be the cluster itself or something else like the wiring????
    can anybody give me any ideas on whats going on?????
    thanks guys goddess xox
    wayvr's Avatar
    wayvr is offline R.I.P AAA-99P
    Vx cluby
    Feb 2007
    nsw
    take it to an instrument repair only cost arounf 60 bucks same thing happen to mine ... commen with that modle of commodore
    __________________
    R.I.P AAA-99P you will be missed !!!!
    i have parts for vr vs vn vp for sale check them out .. they worth the look!!!!
    http://forums.justcommodores.com.au/...-look-nsw.html
    RufusŪ's Avatar
    RufusŪ is offline I Jizzed in my pants
    VR S1 S Pack, VX S2 Acclaim Wagoon
    Apr 2005
    The Marsh, Vic
    The Transducer, the little part that plugs into your gearbox that the speedo and odo get their info from, has crapped its self/broken a wire. bout $100 from memory, pretty easy to replace too.
    Signage, Splash Backs and Display Systems
    "No, I'm not a pessimist. At some point the world shits on everybody. Pretending it ain't shit makes you an idiot, not an optimist."
    wayvr's Avatar
    Vx cluby
    Feb 2007
    nsw
    there are more then that check the cluster first
    __________________
    MiSs MeOw's Avatar
    spankin 1998 VT
    Feb 2007
    ephect's Avatar
    ephect is online now Donating Member
    VS Acclaim V6
    Jul 2006
    goddess, this is a common fault, most of the time its the cog that drives the needle and odometer. the gear can be bought for $5-15. easy to replace and below is the link to the How To.
    Broken Odometer
    Slow VR's Avatar
    Slow VR is offline Another White Crummodore
    VR Series II
    Apr 2006
    Cairns, Nth Qld
    When that little gear fails, it stops the odometer from working, not the speedo. So there is an issue elsewhere, other then that gear failing.
    Jumping Commodores is the right thing to do... Flex is a good thing.
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    I am experiencing a similar fault with my VR II where the spedo sometimes works and then it just stays at zero. The odometer still works and also tried the trick with the speed alert and that displays the speed ok.
    Looks like I am going to have to rip out the dash and get it looked at, or have a look at it myself.
    http://woteva.tk/
    If it ain't broke... I can break it for you
    SlyVR's Avatar
    SlyVR is offline Fo'sizzle....
    VR Wags
    Nov 2005
    talking about speedo's my fuel and temp need a little hit now and then.. does anyone know why i have to give it a little tap here and there.... or any fixes would be great
    thanks all
    MiSs MeOw's Avatar
    spankin 1998 VT
    Feb 2007
    hmmm so it looks like i have to look at a couple of things shouldnt cost me that much hey???????
    wayvr's Avatar
    Vx cluby
    Feb 2007
    nsw
    if u have to hit ur dash to get it to work again then the silicon inside the guage has melted of stuffed .. i no this because when i got my speedo fixed that is what the guy said on cost me 60 bucks from an instrument repairer
    __________________
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    Quote Originally Posted by SlyVR View Post
    thanks all
    the little tabs the needles rest on are sticky. simple but time consuming fix - pull the cluster out and clean with prepsol
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
    SlyVR's Avatar
    VR Wags
    Nov 2005
    Quote Originally Posted by TheForgotten View Post
    Thanks mate i'll give it ago
    RufusŪ's Avatar
    Apr 2005
    The Marsh, Vic
    Quote Originally Posted by goddess View Post
    If both your speedo and odo don't work, I say for certain it is the transducer, but as I've never had a problem in the dash, I can't say that it is 100% the problem.
    Jump under the car, or get your other half to, find the transducer, can't remember which side it is located on, give the wires a wiggle as see what happens.
    What may have happen, which i believe to have happened to mine, when someones changed the clutch, they have either not unplugged the wires or have managed to damage it somehow.
  15. #15
    VRII Acclaim
    Jul 2005
    If you need to tap the dash to fix it, there is either a bad connection or the needle or the 'motor' that drives the needle is tight. You will probably find that taking it out (follow that how-to link higher up on the page) putting a tiny bit of oil on the needle, so that it runs down the shaft to the motor, and putting it all back together will fix the problem. Putting it back together usually pushes all connections back correctly so that she will work again.
  16. #16
    MiSs MeOw's Avatar
    spankin 1998 VT
    Feb 2007
    Quote Originally Posted by damo007 View Post
    ahhh this is helpful coz the guy that i brought it off changed the clutch so i might get my other half to look at the transducer thanks dude
  17. #17
    MiSs MeOw's Avatar
    spankin 1998 VT
    Feb 2007
    Quote Originally Posted by kopper69 View Post
    no the bash the dash trick doesnt work on this problem if its not the transducer ill check the cluster
  18. #18
    MiSs MeOw's Avatar
    spankin 1998 VT
    Feb 2007
  19. #19
    MiSs MeOw's Avatar
    spankin 1998 VT
    Feb 2007
    well ok guys i changed the transducer and there was no change so it might be the cluster but still unsure
    do u think there could be any other reason why the speedo and odo aren't working other than the cluster now that ive changed the transducer???
  20. #20
    MiSs MeOw's Avatar
    spankin 1998 VT
    Feb 2007
    just had a look at the how to link higher above but does that apply for odo AND speedo not working or just the odo not working?
  21. #21
    1997 VS Commodore Exec
    Feb 2006
    just odo if I remember. Stupid question but you checked out your fuses eh?
    <davy> remember when braveheart came out and everyone said you can't have mel gibson playing a scottish guy cuz it wont be realistic?
    <davy> well look at him now
    <davy> an alcoholic racist
  22. #22
    MiSs MeOw's Avatar
    spankin 1998 VT
    Feb 2007
    yeah i have everything seems to be ok in that department im changing the cluster on saturday so im hoping thats all i gotta do if not id have to say im all out of ideas............
    ill have to take it to an instrument repairer
  23. #23
    woteva's Avatar
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Is it a big job to get the cluster out ??
    I have had my VR II for almost 1 week and the speedo not working is pissing me off.
    Any hidden screw's etc or tips from some pro's when removing the cluster ??
    http://woteva.tk/
  24. #24
    MiSs MeOw's Avatar
    spankin 1998 VT
    Feb 2007
  25. #25
    woteva's Avatar
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    go here and it will tell u step by step on how to get ur cluster out
    http://forums.justcommodores.com.au/...ad.php?t=12428
    ^^Link not working^^
    http://woteva.tk/
  1. speedo not working
    By clyde in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-10-2007, 11:07 PM
  2. speedo not working
    By winton in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2007, 10:47 PM
  3. Working out speedo corrections....
    By NORTI in forum General
    Last Post: 26-02-2007, 10:22 AM
  4. km on speedo not working
    By frankyj54 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-07-2006, 01:01 PM
  5. Speedo not working
    By holster in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-10-2005, 11:01 PM
