Hey can anyone help me fix a problem with my aircon?
when I turn my aircon on the compressor starts and it gets cold but the fan doesnt come on. from speed 1 to 4 it does not do anything, the fan just doesnt blow any air out the vents.
Is there a relay or a fuse that I can replace so it works again?
Thanx
Danny.
Does the fan work without the AirCon on?
Signage, Splash Backs and Display Systems
"No, I'm not a pessimist. At some point the world shits on everybody. Pretending it ain't shit makes you an idiot, not an optimist."
Could be a number of things. Start by checking fuses and relays. If you have a multimeter, check fan speed resistor (search fan speed resistor in the how-to section to find info). If you dont have a multimeter, pull it out and have a look at it. Otherwise control box might be playing up or fan might have died. If its none of above listed, its going to be a wiring fault, but thats not very common.
No dramas. Well fuses don't just blow for no reason... so it would appear that there is something wrong with your fan or associated wiring, maybe something has melted in the wiring and is short circuiting? I would probably have a look at the fan motor itself, and the connections and wiring. You should be able to pick up a new one from the wreckers pretty cheap, so maybe pull yours out and swap it over... and go from there.
