Results 1 to 8 of 8
Thread: vn - vr v6 exhust manifolds???
    1995 vr excutive
    Mar 2007
    Default vn - vr v6 exhust manifolds???
    are vnv6 manifolds the same as vrv6 ones ???
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Yes they are. I know the engine pipes are different for auto and manual but I don't think it makes a difference to the manifolds.
    1995 vr excutive
    Mar 2007
    just my ones got a crack in it and im wondering if a vn one will be ok as im having trouble finding 1 here in nz for less than 100bucks for a vr
    LowVp's Avatar
    LowVp is offline VP nut
    VP Ute 3.8T M5
    Aug 2005
    Ipswich, Qld
    1995 vr excutive
    Mar 2007
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    Not worth replacing a cracked cast manifold if they are so expensive! For a couple hundred bucks more you can get extractors on there
    So you get a bit more performance
    Gilbs
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    which side is cracked? i have a rh exhaust manifold for a vr on ebay for 20.
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    id be going extractors the early vn had pipe type manifolds and the vns2 and vp and vr has cast manifolds totally different rarespares catalog says 1991-vrv6 which would be series two onwards so same as late s2 vn and vp rarespares quote $391 nz each they also have pacemaker extractors $539 and hurricane headers $389 cheaper than one original manifold and thats a pair of extractors .
  1. WTB. VS exhaust + manifolds.
    By rexsportwrx in forum Swap / Wanted to Buy / Trade
    Last Post: 10-02-2007, 11:57 AM
  2. exhust help
    By reaper115 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-08-2006, 09:59 PM
  3. whats a good exhust system to put on a vx s2?
    By diontanti in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-07-2006, 10:59 AM
  4. Vp Exhust system
    By MavVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-01-2005, 08:09 PM
  5. Exhaust Manifolds
    By markovr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2004, 09:05 AM
