+ Reply to Thread
Results 1 to 9 of 9
Thread: Tensioners...do they fail?
    VS Exec Series II
    Mar 2005
    Default Tensioners...do they fail?
    Hey Guys,
    I'm due for a coolant change and wondering if I should change my pulley tensioner.
    My current belt is a few years old but last time a new belt showed as needing to be replaced on the markings.
    Anyone had tensioner issues before, the car has done 260k but the idea of removing those coolant pipes worries me a little.
    Thanks
    Clacks
    1997 VS Commodore Exec
    Feb 2006
    Do you mean the belt or the pulley? or something else?
    I have the tensioner pulley's replaced but only because they were noisy.
    <davy> remember when braveheart came out and everyone said you can't have mel gibson playing a scottish guy cuz it wont be realistic?
    <davy> well look at him now
    <davy> an alcoholic racist
    VS Exec Series II
    Mar 2005
    Quote Originally Posted by Spaced View Post
    The tensioner itself. I have replaced the pulley.
    Thanks
    Clacks
    VS Acclaim V6
    Jul 2006
    yea i've replaced a tensioner arm before, only coz i stripped the bolt that holds the pulley on, didnt relise it was left hand thread..
    yes the do 'fail' what happens is the spring that holds tension, gets 'loose' (for a better word) or looses its retension rate i spose and in worse cases they can get quite noisey..
    not hard to do, but i believe u have to undo the alt and place that out of the way, drop the hose, i think its a heater hose, undo the bolts holding it on, replace and reverse the above proceedure.. but topping up fuild levels
    hope it helps a lil
    VS Exec Series II
    Mar 2005
    Quote Originally Posted by ephect View Post
    hope it helps a lil
    yeah it does, thanks. Any idea how much fluid you lose when changing it over or is it pretty much a refill?
    Clacks
    VS Acclaim V6
    Jul 2006
    nar u dont loose too much from memory, which im starting to loose anyway.. who are u? jk
    like u meantioned in ur first post, might as well do the tensioner arm and the coolant change the same day.. ur gonna lose some fuild anyway, best to drop it all, give it a quick flush (how-to section details this well) and ur ready to roll again.
    Slow VR's Avatar
    Slow VR is offline Another White Crummodore Slow VR Executive
    VR Series II
    Apr 2006
    Cairns, Nth Qld
    They sometimes generally make clacking or clicking noises when they fail.
    Jumping Commodores is the right thing to do... Flex is a good thing.
    hako is offline Donating Member hako Senator hako Senator hako Senator
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Clackers - why do you want to replace the tensioner? - unless its worn so bad that it makes the pulley run off-line it should be OK?
    AttaBoy is offline WTF?!?! AttaBoy Statesman
    VS Acclaim V6
    May 2005
    Don't forget to bleed the coolant when you top it up after you replace the tensioner!!!
+ Reply to Thread
  1. Calais Dash Diagnostics = FAIL
    By slimman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-09-2007, 04:56 PM
  2. VK taillights dead - anyone know where they commonly fail?
    By synoptica in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-12-2006, 07:27 AM
  3. ECOTEC big ends, why they fail
    By portercg in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-01-2006, 12:10 PM
  4. ECU fail-safe mode?
    By mrhaboobi in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-09-2005, 02:15 PM
  5. intermitant engin fail
    By Spin in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-08-2004, 12:47 PM
