hey i recently installed a new sound system in my vr berlina HSV and everything went well but when i switched the car on the screen on the dashboard under the kmph which displays how many kms the car had done does not appear, the green light appears just no lighting, also when i put my lights on the car gauges, kmph or anything lights up which it is supposed too. any ideas??? need help fast
thanks
You may have pulled some wiring loose from behind the dash when playing in there. Reach up and push all the plugs in if you can without pulling the dash out.
sounds like a plug as abba said
never heard of a Berlina HSV before.....
WTB VR/VS FACTORY HEADUNIT BRACKETS PM MEOriginally Posted by MY-42-VT
Probably means Berlina and HSV????!!
As abba said it could be the wiring, but in my case, when I pulled the dash out to be painted, some globe didn't light up (plugs are alright) and I found that they are quite delicate and can be damaged especially in a car that age. I went out to buy new ones. So if you check the plugs and still not working then it means new globe.
