Results 1 to 13 of 13
Thread: Help Please.v8 Starting Problem
    vr 5 spd v8 commodore,v6 vp.
    Sep 2006
    new zealand
    Default Help Please.v8 Starting Problem
    hey guys.I have nearly finished my v6 auto conversion to v8 manual.thing is it turns over but wont start.there is fuel in there and there is also spark.does n e 1 have any ideas on what my problem is.any replies appreciated.thanks guys
    POVRTY's Avatar
    POVRTY is offline building 5L VB TH 400
    VE SSV 6SPD WGN
    Dec 2005
    taree nsw
    Sep 2006
    new zealand
    yeah timing is correct..i had a m8 check that out.he rekons it something a bout some wires that plugd in2 the shifter when it was auto.but i duno
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by v8srbad View Post
    Does the VR use the same ECU for manual/auto? When you did the swap did you use a complete pakage from 1 donor car or collect bits and put it all together that way?
    and 3 Dangerous non ABS VN's
    POVRTY's Avatar
    VE SSV 6SPD WGN
    Dec 2005
    taree nsw
    Sep 2006
    new zealand
    i have the donor car with me.i have taken everything from it.inc ecu,exhaust,suspension...everything.
    Sep 2006
    new zealand
    Quote Originally Posted by POVRTY View Post
    if it was the park/nuetral switch i dont think it would wind over?
    yeah my m8 cut these wires that plug in2 the shifter and joined them 2gether.b4 that the car wouldn't turn over.now it does but wont start.
    fuel_within's Avatar
    fuel_within is offline Chief Executive
    CUSTOM VS
    Oct 2003
    VRII Acclaim
    Jul 2005
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    All the leads are correct? The engine actually ran in the donor car too I presume. If you have fuel and spark, it could only be a timing or compression issue.
    CUSTOM VS
    Oct 2003
    Sep 2006
    new zealand
    Quote Originally Posted by fuel_within View Post
    Body Control Module?
    yeah i've changed that over.it started the other day but cut out.wont start nw
    Sep 2006
    new zealand
    Quote Originally Posted by Not_An_Abba_Fan View Post
    yeah leads are correct and the engine was running b4.i shud no it was in my old ride which i wrote the ass end off.lol.im gona get it compression tested.
  1. VN starting problem
    By wes_v8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2009, 04:58 PM
  2. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  3. starting problem
    By glowworm in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-05-2007, 10:49 PM
  4. starting problem
    By whatisnttakenalready in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-02-2007, 10:29 AM
  5. VN starting problem
    Last Post: 11-12-2006, 10:21 AM
