Taken fron Street commodores issue No 91 (November 2004) page 137
1, disconnect the electrical connection and fuel line. ( I think you need an empty fuel tank, maybe, i dunno)
2, remove the 7mm bolts that retain the fuel pump pick up and sender assembly; remember the oreintation of the fuel outlet so it goes back the right way.
3, carefully slip the whole assembly out and replace pump in the same position and reconnect wires and fit fuel filter. (it takes a bit of fiddling around)
4, refitting is as much fun as removing, be careful not to displace the filter while putting it in the tank.
5, put bolts back in and plug it back in.
should take about 1/2 an hour to an hour depending if you have a hoist or not.
This was taken from street commodores where they upgraded the pump to a better one.
