guys,
was in a stack yesterday, not too bad (did hit a beema though) and was wondering how to remove my front bumper... any help will be appreciated...
thanks in advance
luke
Loudness - the intensity of sound!
www.globalhardstyle.com
check it...
theres 4 17 or 19 ml bolts were the reo bolts on and some smaller 10ml bolts near the wheel arche meets the bumper if you pull the front of the inner gaurds off u will c them no worries undo the screws near the grill and..............i think thats it?
isnt there a coupla bolts behind the numberplate?
How to be a good Australian Citizen: Drive a Camry, Become another number in the system, Dob in all other numbers for un-numberlike behavior (no matter how slight), Base all your opinions solely on the information provided by T.T. and A.C.A., Believe everything our gracious Government Tells you to.
Yes there are. Gregorys shows you every nut and bolt holding it on. It is clipped in too, so it might be a little tight when you try and pull it off.
sorry for reopening this post...
if the holes on the sides (where bumper screws in - in wheel well) are broken, can you patch them?
See My Ride: VR
