could some-1 show me a diagram of the underside of a VS of where i should propely jack it up from and where do i place the jackstands? i am using the hydraulic type car jack not the flimsy factory jack
accordin to my vs calais factory manual there is two points on either side of the car to jack from and they can be located by the half circle cut out on the lower sill!
Also is you want to jack the entire front end up ,the center of the crossmember. and to jack the whole rear end ,the diff.
Power is measured in DECIBEL
