Page 7 of 8 FirstFirst ... 345678 LastLast
Results 151 to 175 of 179
Like Tree6Likes
Thread: VS v6 owners check this out
  1. #151
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    A FRIEND PULLS INTO HOME,WENT INTO EAT, SMELT SMOKE,WENT OUT TO THE FIRE BALL CALLED (HIS CAR) THE WIRE HAS STARTED A SMALL FIRE IN THE THE ENG BAY(when he hopped out he didnt smell the small fire)only to return to a big fire)THE FIRE BRIGADE TOOK THE CAR FOR FOR INSPECTION AND THAT RED WIRE WAS FOUND TO BE AT FAULT
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
  2. #152
    Did have VS Berlina now have VT Berlina
    Mar 2010
    Cockatoo Vic
    ok it hasn't happen'd to mine yet but i wan't to rewire it all what would be the best wire to use (0 gauge)? and were can i get a roll of it for cheap?
  3. #153
    VS II Executive
    Jan 2011
    Rocky, QLD
    Hi, bought my vs II executive in desperation about a month and a bit ago, happy to find this forum/threads. Have checked my red wire connection and its all good from what I can see/feel.
    The fixit list is growing, guess thats what I get for buying the unknown in the pouring rain hey The suspension guys are telling me a $1000 story, the odometer is dead so after 196k's who knows lol! Ive named it turtle.
  4. #154
    Sep 2005
    when all the probs are fixed she willl run like a dream,fix list realy never end lol,,,,name it lion not turtle lol
    Quote Originally Posted by justy View Post
  5. #155
    Vs 2 aclaim wagon
    Jan 2011
    canberra
    I've checked this on my Vs s2, it looks to have been repaired already, thanks for the tip....
  6. #156
    Sep 2005
    thats good at least your will be ok for years to come....cheeeeers
    Quote Originally Posted by fireballv8 View Post
  7. #157
    VS Commodore sedan
    Feb 2011
    grafton
    ok i've read this thread a thousand times but there are conflicting answers
    my alternator cable is burnt near the terminal (it broke when i touched it)
    i need a solution that will last me 4000ks until i can fix the problem permanently
    advice in the thread is 2 answers;
    1. cutback the wire to a point it's good and redo the connection
    some posts say that shortening the wire will increase resistance and i can expect even more heat on the wire, but will it last me 4000ks?
    also, i'm worried about electrical safety, when the broken cable touched the body of the alternator it sparked. do i have to disconnect the battery before working with this cable? don't want to have large amps running through my body when trying to cut and reconnect this damn cable
    disconnect battery is always neg first and then pos right?
    2. run a thick cable direct to battery
    i guess the earth cable that runs parallel with the main cable still works so i can just cut the main cable near the battery and run a separate main cable direct to the battery
    but i also read that the main cable is forked to the circuit breakers?
    do i need to run a separate cable to the breakers? and from where? the alt or the battery?
    or can i just skip it as it only has to last 4000ks?
    any thoughts much appreciated
  8. #158
    commodore 95 exec
    Feb 2011
    Queensland
    VS II Manta & VC Commodore
    Apr 2011
    TRAFALGAR
    Thank You Thank You.....
    I was struggling to find a solution to issue surrounding my old man's VS ute.. The cable was buggered I have repaired it and all seems to be well it was a fire in the making..
  10. #160
    VS Executive Series II
    Nov 2010
    VR Executive 3.8
    May 2011
  12. #162
    VS Acclaim
    Feb 2011
    NSW
    Well... Now I cannot wait for the morning to go and have a look.
    I bought a 1996 VS Ecotec Wagon Acclaim in February 2011 with 273Km on it.
    I only had it for two weeks, when it almost refused to crank up and I immediately suspected the battery.
    I went to the garage and got a new battery.
    Went to the corner shop after that, and when I came out, it was dead as a dodo.
    I went back to the garage, and since the car was only 100 metres away, we pushed it.
    The guy put a new starter motor in it, and it was still dead as a dodo.
    So he traced an electrical fault to the battery terminal.
    He just tightened the clamp around the red cable and it started.
    This morning, 4 months later, car was dead again.
    It turned out that the battery was flat and I have no idea what drained it.
    Nothing was left "ON".
    Also, a stupid question
    Where is the switch to turn the ceiling light on/off
    The light has not worked since I bought the car. When I changed the bulb today, the light came on and I cannot find the switch to turn it off.
    MAD about Bathurst. http://www.aussies-online.com
  13. #163
    VS Acclaim Series 2
    Oct 2011
    Perth - Cockburn
    If only I signed up earlier, I woulda known. Got an entire new alternator, oh well, might be good in the long run.
    Oh, and the light for that (I had this problem too, for a day or two) is next to where you turn your headlights on. Like right on the left of it. It also adjust the brightness of the dash lights if turned all the way down.
  14. #164
    99 vs statesman
    Oct 2011
    sydney
    just bought a vs statesman with 166k on the clock D: thanks for the heads up mate will be checking it this weekend!
  15. #165
    VS Acclaim
    Feb 2011
    NSW
    Interestingly... my alarm would also go off everytime I was putting it on.
    So for 5 months I would leave the car open.
    It turned out that the alarm went off, because the switch for the ceiling light was in the "on" position.
    But I did not know because the bulb of the ceiling light was burnt out.
  16. #166
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Hahhaa... dammit, I JUST Read this thread today..and the SAME problem had occurred on monday !! HAHAHAH...
    Thought the alternator had died, was draining batteries so quick.. So we went to take the alternator off.. to see the Red Power wire had 'broken' ..
    Thank god I had great help thanks to an Auto-lecy bud !
    But the thing, my wagon has only done 107-XXXk's .. But, I guess its a crappy wire lol.. So instead of fixin the same wire , he just replaced the whole wire.. Now the wagon is happy and is not eating its batteries
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
  17. #167
    vs series 2 wagon executive
    Oct 2011
    castle hill
    Thanks for the heads up. I had no idea about that and mine was very burnt out.
  18. #168
    BuckeTs's Avatar
    BuckeTs is offline Filthy Beast
    vs wagon
    Oct 2011
    Just checked mine, insulations knackered. :/ might get some 0 gauge this weekend then
    When in doubt, use FORCE
  19. #169
    vs commodore s pack Manual
    Aug 2011
    ryde
    Far that happened twice too my commy in the first two weeks of having the car and fix the problem my self all sweet as now ay
  20. #170
    VS Acclaim Series 2
    Oct 2011
    Perth - Cockburn
    This happened to me in a Red Rooster drive-thru lol. Had 189k on the clock, unfortunately bought a new alternator then saw this thread. As my mate was replacing the alternator, he saw that the wire was the problem. :|
  21. #171
    Vs Exec S2
    Jan 2012
    Caboolture, Queensland
    Been There Done That, Luckily i knew about it before hand, then the stupid thing decided to fry from the other end! dam cars some times!
  22. #172
    VS 9C1 Executive
    Feb 2012
    Launceston, Tasmania
    FML!!
    If I seen this 5 weeks ago I would of been right. Mine was this problem. I'n not all up there with mechanical stuff. My battery light had been on and off for a few months and then I noticed my sound system cutting out in portions and within half hour my car stopped. My VS has 189xxx kms on the clock and I just thought my alternator had just packed it in. Went and got a second hand one and off I went. Within a few days same problem again. I left it and thought maybe I had bad luck with the alternator I got and borrowed one off a friend and then same issue again. First thing to think is obviously the wire coming from the alternator. Mine was black and stuffed and pretty much snapped off with barely any force. $3 for cable lugs to fix. Good to see its a common problem and people are made aware of it cause I would be absolutely pissed off if I forked out $200+ for a brand new alternator.
    Good work!
  23. #173
    vr commodore
    Feb 2012
    adelaide south australia
    hey ive just brought a second hand 1995 vr commodore v6 , converted to a manual.. i went to start it this mornin n it wouldnt start , i put the battery on charge till it hit full put it back in but it didnt turn over . only the oil,park,and battery light came up on the dash . i checked all the fuses replaced a few of them even replaced the battery but it wont turn over , any tips on how to get it runnin
  24. #174
    vr commodore
    Feb 2012
    hey ive just brought a second hand 1995 vr commodore converted to a manual. i went to start it this mornin but it didnt kick over . i checked the fuses . replaced the battery n it still wont start . any tips on how to get it goin
  25. #175
    VS S Commodore
    Oct 2011
    Thanks mate! i will check this because its done it 3 times and i replaced the battery and its been great since ! ( replaced it the day after it wouldnt start a 3 weeks ago )
  1. V8 Owners????
    By andrewownsavp in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2007, 07:19 PM
  2. gen 3 owners help, please
    By cpbait in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-12-2007, 07:57 PM
  3. VY SS Owners...
    By Torquen in forum Swap / Wanted to Buy / Trade
    Last Post: 21-03-2007, 01:26 AM
  4. Gen III owners....Check your hoses!
    By Lumps of cheese in forum General
    Last Post: 04-01-2006, 08:05 PM
