jazza21
Executive (Ex-Police)
- Feb 15, 2004
- 162
- 1
- 0
- Location
- Runcorn, Brisbane
- Website
- www.cardomain.com
- VS II Exec 1997
Just discovered a new little problem (or maybe it's a big one). Here goes, it's a long story, but as far as I can tell there's no other posts directly relating to this.
I noticed a pool of coolant in front of my car when I went back to it at a shopping centre today. Thought little of it, it seemed to be drying out like it was from the previous car parked there. Anyway I drove home, parked car on the street and went inside. Was home for maybe an hour and went out to my car to go for a drive. Sure enough there was the coolant again... So I topped up the overflow tank to the MAX level (it was empty) and checked if I could see where the leak had come from. No leaks anywhere but the liquid seemed to have only come from the overflow hose that goes down to the road. Went to a mates place a few K's away, parked car, went upstairs for 20 minutes, back to car, no leaks... So I assumed it was alright. Anyway next drive, next car park, check for leaks before I go, all seems fine. Went to a movie, came back about 3 hours later and there it was again, all across the car park, and this time there was no doubt as to it's origin - the only place any liquid was expelled was the overflow tank's extra overflow hose (the one that leads down under the car to the road).
I replaced the whole tank a few months ago, new cap, whole system flushed, checked and rechecked. All OK. The remaining coolant in there now is bright green, no discolouration, no oiliness, just less of it still in the radiator. The tank itself and all the normal hoses etc. are not showing signs of deterioration or fluid loss.
The only thing I can put it down to is remaining pressure when I turn off the car, which forces extra coolant up into the overflow tank, which fills it too much then goes out the other pipe to the ground. The car has not been overheating and is otherwise running just fine.
I really need some help here with this one. Other than going for a preasure test I have pretty much exhausted all options I can think of.
Any suggestions?
Jazza
Any suggestions?
Jazza
