today i went for a roady and got knocked back for unsecured pod,upper contral arm bushes and too low. we fixed the two low problem with me showing the guy its not too low (just a d*ckhead) and i went to get some new bushes but everywhere has told me they do exchange control arms, and im not paying over 100 bucks for something that is not needed when all i need are two rubber bushes, does anyone know where i can get some bushes for it, even if they are for another part of the car but can be used for the same purpose?
i had to replace my upper and lower control arms. it was about $15 more expansive per arm to purchace the whole arm with bushes already installed. i bought them from auto1 and they are nolathane brand
and i got to keep my old arms 2
how much did you pay for each arm (upper)
im not sure? i bought all 4 about a year and a half ago. not real helpful ha?
I can do SuperPro polyurethane bushes, kit comes with four bushes and four crush tubes (kit does both ends of the control arm), $65 plus postage. I assume it's a live axle and not IRS?
Visit my Facebook page
Nuff said really.
1999 VTII SENATOR
YOU BUY!!!
ALL SERIOUS OFFERS CONSIDERED
http://www.carsales.com.au/private/d...o=Stock&items=[Make:HSV,Model:SENATOR,Series:VT%20II]&sort=default
you need a hydraulic press to remove/replace the bushes, that's why exchange arms cost more, plus they're re-painted. arms are all the same unless you hve aftermarket boxed arms
WTB VR/VS FACTORY HEADUNIT BRACKETS PM MEOriginally Posted by MY-42-VT
As theforgotten said the bushes that are in your current arms are a press fit.
If you have the use of a press then they are not too bad to change.
I just did mine last week using the change over arms and it took me about 15 minutes per side to change them over.
If you buy just the rubbers then you are going to have to take your arms out drive somewhere to get them pressed out and new ones pressed in then drive back and put it all back together.
My advice is by the arms that are done and save yourself some time.
I paid about $40 each arm i think it was. I got mine from Burson Auto. Well worth it.
you dont need a press, just a good well mounted vice, a few pieces of odds and ends like nuts, a few bolts and different sized washers.
You can then use the vice to force the old ones out and the new ones in with ease.
I did it on my rear upper control arms, Rubber bushes can be bought from holden service centers spare parts section for about 20 odd dollers each. Personally I refuse to use nolathane on anything except the sway bar link arms, simply because I hate the rougher ride.
If your in Melbourne i'd be happy to help you.
