Hello
The problem is when the Engine is Cold It cranks at normall Speed but As soon as it gets Hot It Only Just Starts Up, I took It Into a garage And They Checked The battery and Alt And The Battery And ALT Is All Okay..
I was Told That There Might Be a Earthing Problem.. Dose anyone Know what i Could Try To sort This out??
Thankyou
starter motor? solenoid loose on it? check wires... my starter starts the other way around lol
Slow-cold and Hot-fast
good luck
I'd suggest that heat is getting into the wiring somewhere. apparently heat can degrade a wire's conductivity
wavez - change your voltage regulator
WTB VR/VS FACTORY HEADUNIT BRACKETS PM MEOriginally Posted by MY-42-VT
Sounds like the heat from the exhaust is getting into the starter motor solenoid, and giving you problems.
yeh for some reason im getting cold - fast and hot - slow untill my fan comes on and makes it cold so i go fast. hmmm i think my fan is dead 2 coz it heats up past half way prob 2 lines from half way i go to take off and i feel like there s huge lag spot and im loosing power.
RAJAB RACING
FullBOOST
PRESTON AUTOMATICS & DIFFERENTIALS
etstreet.com
This may not be the same prob but my old XD used to do the same . I had an auto elec wire up a relay to the starter motor which solved the problem
Sounds like your starter motor is on its way out - either brushes worn and/or bearings dry. They slow down when hot due to internal electrical resistance being greater than when cold.
