fuel pressure regulator
harro_VR
Boosted VR
Hervey Bay
vr Berlina turbo, VZ SS
Hey guys just wondering where the fuel pressure regulator is located on a vr v6.
thanks Matt
AttaBoy
WTF?!?!
VS Acclaim V6
Should be behind the driver's side fuel rail.
harro_VR
Boosted VR
Hervey Bay
yeah thats where i thought it was.... wats the thing behind the throttle body elbow?
Chirpstr
A new project attack
VR Berlina M5, VP M5
fuel damper?
harro_VR
Boosted VR
Hervey Bay
ok thanks :) so how would i go about putting my rising rate fuel pressure regulator in because i was told today that i have to remove my stock one and then how does the hose connect in to the fuel rail?
Chirpstr
rising rate fuel pressure? not stock?
Chirpstr
If it is the same just take the fuel pump relay out and hold the key on for about 5-10secs this will drain the fuel undo the clamp holding the fuel return hose and remove vacuum hose. Remove the bolt holding the regulator to the fuel rail. ..
Make sure nothing goes in the rail when swapping them around. Maybe put a rag in there...Install the new O ring with a bit of oil and connect every thing back up reverse
Chirpstr
ok...then why are you changing it?
