Results 1 to 7 of 7
Thread: TCC lockup question
    VS Exec Series II
    Mar 2005
    Default TCC lockup question
    Hey guys,
    Took the car for a rap up a hill this morning. Was in 3rd doing 80 and got a rumbling sound that I'm almost positive is the TCC slipping. Only happened when the hill started to get steep and the car was working. Sound was similar to a noise I had back in 99 when I first got the car which was the TC.
    Just to confirm, I'm pretty sure the TCC locks up at 55km in 3rd...anyone enlighten me?
    Thanks
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    G'Day Clacks, dunno for sure but I always thought the TCC only locked up when the car had quit accelerating and was basically "cruising" with the speed above 80kph. I know it only needs a slight nudge on the accelerator to disengage....maybe engine vacuum is part of the requirement as well as well as vehicle speed and gear engaged. I'll bet when you got the rumbling sound your back pocket started feeling uncomfortable! Good Luck.
    AttaBoy is offline WTF?!?!
    VS Acclaim V6
    May 2005
    VP Executive R-spec
    Jan 2005
    Jun 2005
    TCC lockups on at a certain TPS percentage reading. depending on the speed youre going, the tcc will lockup at a different TPS reading.
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    VS Exec Series II
    Mar 2005
    Thanks for the responses guys.
    When originally replaced, the installer had troubles getting the TCC to not slip, it went back a few times and they said they changed some things. Maybe lock up points were one thing they did. I can see the revs drop a hundred or so on the tach so I'm sure its lockup.
    Ideally I'd like to disable lockup but I don't think there is an easy way. I might ask a holden dealer if they can do anything there.
    Thanks
    Sep 2007
    mines doing the same thing atm...
    at 80k's in 3rd or if im just cruising at 100k's and put my foot down just a bit it'll make that rumbling sound...so is that the tc??
    whats the go with getting that fixed?
    Cheers, Ben.
  1. 'torque converter lockup issues'
    By bAAAz in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-10-2006, 05:05 PM
  2. 'torque converter lockup issues'
    By bAAAz in forum Electrical Wiring / Questions
    Last Post: 14-10-2006, 09:13 AM
  3. Disabling torque convertor lockup - possible?
    By Clacker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-04-2006, 10:55 PM
  4. Auto TCC lockup info
    By EHVS in forum General
    Last Post: 08-02-2006, 08:50 AM
  5. Torque converter lockup
    By hophoar in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-09-2004, 08:37 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
