Results 1 to 6 of 6
Thread: ecotec idle speed adjustment
    '87 VL Calais with L67
    Aug 2007
    Default ecotec idle speed adjustment
    anyone know how to bump up the idle revs in an ecotec? i want it to sit on 1000 cos i think its a bit low where it is.
    AttaBoy is offline WTF?!?!
    VS Acclaim V6
    May 2005
    It should be around 700rpm mark. try cleaning the throttle body and the Idle air control solenoid.
    I'm not sure if idle can be adjusted on the ecotec.
    VP Exec
    Jun 2005
    Not adjustable (except if you have the means to change the values in the PCM). Acclaimed, why are you second guessing the GM engineers?
    Aug 2007
    im not second guessing im third guessing. hsv are the second guessers lol i just want it to idle quicker to reduce carbon emissions. lol.
    i think i need to clean iac. i cleaned the carbon off the valve but not the tb where it seals and that. i cleaned around the throttle body butterfly too.
    what does the screw on the butterfly linkage do? its makred with white paint. anybody know?
    VX SS M6
    Jun 2005
    VP Exec
    Jun 2005
    The screw sets the minimum possible idle speed by setting the most closed position of the throttle plate. The PCM controls the idle speed with the IAC valve (in conjunction with ignition timing and fuel:air mixture) by allowing greater or lesser amounts of air to by-pass the throttle plate.
    It is possible to open the throttle plate using the screw far enough that the PCM/IAC no longer controls the idle speed, but why do so?
    The white paint is to provide indication of tampering. There is really no (or very few) good reason(s) to move it anyway.
  1. ECOTEC idle problem
    By syk35 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2011, 11:24 AM
  2. Fluctuating idle on deceleration in 3.8 V6 auto (ECOTEC and non-ECOTEC)
    By cliffo78 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-04-2009, 12:02 AM
  3. Ecotec Stumble off idle.
    By squidda in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2006, 11:34 AM
  4. how does the ecotec engine idle?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2006, 03:35 AM
  5. VT V6 Ecotec Idle Revs Range
    By iamset69 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-12-2005, 10:58 AM
