Results 1 to 8 of 8
Thread: Electric window conversion
    vr Commodore
    Aug 2006
    Default Electric window conversion
    Was wondering, with a electric window conversion do i have to replace the wireing loom in my car, or is it already there. Also will it work with my mid series BCM to do i have to go for hi. I have an acclaim if that makes any difference. Help will be appreciated, thanks.
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Mid series bcm should be ok for power windows..check out for the 2 plugs in the console under the radio that go to the switches that will tell you if you have the wiring already in the loom ....if they are there all you have to do is install the motor units in the doors and install the switches in the console and the rear doors.....you will probably have to replace the looms in the rear doors for the rear motors and switches.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    Silver surfer is offline Banned
    04 VY Executive
    May 2007
    thats all true just finished putting power windows into a vs ute, when we did it all the cables were already in the doors and under the stereo ready for connection.
    Gus The Snail's Avatar
    Gus The Snail is offline Born to be dizlegzic
    VS ute S2 1996
    Aug 2007
    ipswich - on the right side of the tracks
    you were lucky , my ute didnt have any wiring , but i managed to get it as close to factory as possible..
    Back on topic , check the underdash fuses , number 5 controls power windows , see if all the wiring is there for it , and the door plugs will have 2 thick wires ( cant remember colours ) in the middle of the plug..
    I started a power window topic not that long ago , so if you do a search , all the info you need will be found
    Its not what you know or who you know , its how well you can fake it
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    as posted by the guys above..
    check u have both contacts in fuse position 5, and also the contacts in the power window relay. being an acclaim u should have the wiring under the console and in the doors. if your lucky u'll have the wiring in the B-Pillar. if not, u'll have to get the loom that runs from the kick panels to the B-pillar, and then the loom from the B-Pillar to the rear doors. i have an acclaim and the wiring was run to the pillars. i extended the wiring into the doors, and semi-bypassed the bcm. the only feature i dont have is the auto down. but the power windows work when the doors are unlocked and is time limited as is the interior light.
    Parts u'll need:
    4 window regs
    switches
    circuit breaker (fuse)
    relay
    couple packs of 5mm bolts about 20mm long
    couple packs of 5mm nuts
    some male & female spade terminals if u extend wiring urself not using a loom.
    time and paitence.
    the HOW-TO is a good guide gettin it all in there.. post up for all or PM me if u need a lil more info with the bcm bypass
    Hobbes's Avatar
    Hobbes is offline Hobbes
    1996 VS Acclaim
    Oct 2004
    Question
    Pm sent
    Bypass the bcm you say??
    any help on getting the drivers window to work would be great!!
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    just finding the documents now
    Nov 2003
    northside brisbane
    I just used a vp window loom (separate on these models)and module...2 x 12v power connections...12v constant and 12v ign, one wire to the body for earth and also a wire that teed off the door switch wire....the rest was plug and play.
  1. VS Electric Window Conversion
    By Mallee308 in forum Electrical Wiring / Questions
    Last Post: 06-05-2007, 08:42 PM
  2. vn-vs electric window conversion (need wiring diagrams*
    By wizza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2006, 07:06 PM
  3. vn-vs electric window conversion kit!
    By wizza in forum Parts And Other Items For Sale
    Last Post: 29-05-2006, 10:15 PM
  4. VS Calais – Electric Window Help
    By BlackVXGTS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2006, 09:59 PM
  5. Electric Window Intelligence ?
    By sixshooter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-02-2006, 08:56 PM
