Results 1 to 13 of 13
Thread: Whats causing the beeping!!?
    VS Berlina S2
    Aug 2004
    Mandurah, WA
    Unhappy Whats causing the beeping!!?
    Only started today, drove her for a few meters and she started beeping at me (the sound it makes when you have your handbrake on).
    Every 2-3 minutes it beeps again.
    Also the light on the dash doesn't come on anymore when you do put the handbrake on.
    Where do I start?
    Thanks in advance.
    VS Berlina Series II
    slipstream001 is offline -=Slipstream=-
    VR Senator II
    Jan 2007
    Werribee, Victoria
    hi, try changing the globe in the cluster for the handbrake. had the same problem and this fixed it for me
    hope this works
    Summer-Sickness's Avatar
    Summer-Sickness is offline 2005 VZ EXEC
    05 VZ Executive
    Jan 2007
    Rockingham, Perth
    if that doesnt work unplug it... if that doesnt work then u have the same problem as me... and in that case i cant help u :P
    REHAB IS FOR QUITTERS!
    MY 2005 VZ EXECUTIVE
    VS Executive S1 Station Wagon
    Sep 2007
    it's a sticky switch. the switch is sticking and the car thinks the handbrake is on. put a little bit of oil into it. also check the bulbs as above
    pen15's Avatar
    pen15 is offline mathew
    Commodore vr
    Nov 2007
    sutherland shire
    my dad in his vr had a problem with the little toggle switch under the trim i just pulled of the trim and adjusted the switch to where it needed to be so the light wouldnt come on when the hand break was off
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    hey how did you adjust the damned thing, I need to pull the switch out of mine to reconnect the wire, any advise would be great as I dont want to be pulling the seats and the heandbrake lever all out.
    VS Berlina S2
    Aug 2004
    Mandurah, WA
    okay i replaced all the globes behind the dash, fixed the beeping problem!
    now that all my warning lights are working i see that my airbag light isn't going off.. it just stays on (no beeps) do i need to get the airbag looked at/serviced or something?
    Sep 2007
    Quote Originally Posted by PsYko View Post
    yeah the airbag light indicates a problem with the air bag, probably needs a code cleared unless you're positive all the other bulbs are ok of course
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Airbag light can only be reset by Holden. While they are at it, they will check for errors. You didn't do a stereo install and turn the key on while the airbag was disconnected?
    Visit my Facebook page
    vn/vp Speedway Street Sedan
    Sep 2005
    2 seperate friend had the air bag light come on both of their cars.
    Turned out to be alternator for one of them???
    The other guy was a stereo job like NAAF says!
    Good luck!
    Nov 2007
    My airbag light came on when I was swapping relays around under the dash-I was fixing my blinkers,Buggered relay.- Went to Holden,they said come back in two days,Typical .Needed it fixed for rego,so I went up the road to ultratune.They plugged their computer in under the dash,One minute and the light was off and all fixed. It had logged an error in the srs system.I learnt my lesson ,Don't pull relays out from under your dash unless the key is OFF.
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Quote Originally Posted by lg2m30gu4 View Post
    Why in your right mind would you pull out relays with the key on in the first place. Common sense
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    VS Berlina S2
    Aug 2004
    Mandurah, WA
    eep.. more problems (this one seems to have started when i took out the dash face) cruise control turns on (green light on dash), but orange light flashes on then off when i try to set the speed..
  1. beeping in the cluster
    By slipstream001 in forum Electrical Wiring / Questions
    Last Post: 16-11-2007, 02:57 PM
  2. Stupid Beeping!!
    By frenzal_tom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-11-2007, 03:05 PM
  3. car kept making three 3 beeping sounds???
    Last Post: 16-03-2006, 05:12 PM
  4. PCM causing MAT problems
    By srey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-02-2006, 04:19 PM
  5. vl beeping?
    By sully in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-03-2005, 03:15 PM
