Results 1 to 10 of 10
Thread: Tranny revs in 1st gear but barely moves
    BF V6 Falcon
    Jun 2005
    Default Tranny revs in 1st gear but barely moves
    Hi Guys,
    I've noticed over the last couple of months, if I'm taking off and the tranny (auto) is cold, and revving at around over 2,000 the car barely moves (just revvs). I basically need to keep it under around 1500rpm, then until it moves into 2nd gear, I can rev it to about 2000+ no problems.
    Doesn't happen when the transmission is warm however, only cold. I haven't had the tranny slip, etc in the past.
    Any ideas?
    vs calais eco
    Sep 2006
    Disney land!
    my vl was similiar! it would go no where when cold in the morning but after a few minutes she would warm up and be fine, according to the gear box place i took it to (a reputable place) the bands have had it and an over haul was in order! so i would say your probably in the same boat? might sound dumb but i take it you have checked the fluid levels? also maybe get the shifter hydralic valve checked out?
    lc torana. vn v8. ke30.mazda 1300.
    Mar 2006
    yea mine started doing that in reverse your bands are rooted
    wrecking VL COMMODORE 5 speed
    FOR SALE : supra 5 speed box suite holden v8 $800
    VS L67 Statesman
    Oct 2006
    Melbourne, VIC
    Quote Originally Posted by johnnyk View Post
    Hi Guys,
    Any ideas?
    I have the same problem
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Unfortunately it looks like a few people are up for reconditioned transmissions
    Unless you have a mate in the auto trans business the options are either a reco unit fitted for $1000 to $1800 or one from the wreckers.
    Last stand options (apart from checking fluid level with fingers crossed) is to add a reconditioner - Lucas or similar......may keep it alive till after Xmas.
    System's Avatar
    System is offline Control is a way of life
    2005 VZ commodore exec
    Oct 2007
    u'd be walkin on a tight rope if u opt for a second hand one- it might have a similar, or even worse problem with it, u may as well save up for a recon one, it'll last alot longer then ur typical scond hand-thrashed trans
    AttaBoy is offline WTF?!?!
    VS Acclaim V6
    May 2005
    BF V6 Falcon
    Jun 2005
    I was giving her a wash the other day, and checked the tranny fluid level. It was on the lower end of 'normal.' I topped up a little bit, and since its been ok
    I've had the tranny serviced little over a year ago, probably due for another one.
    I guess my seals must be leaking.
    Bilbs's Avatar
    Bilbs is offline Donating Member
    VR 5.0 M5 Ute
    Apr 2007
    Churchill
    first things first, check the fluid level in it, start the car, get it warm, then with engine running in park, check it on the dipstick, should be in the hot range, if not, top it up, if it is, is it red, or black, if it is black, then you most likely need a newy, if it seems to take a long time to go into gear when you start it up, then that is burnt clutches in it, if you have no drive at all, then you have definately gotten the most outta it, but in that case, you can usualy still just feel it go into gear, but not enough clutches, or oil pressure to engage fully, which is my last piece of advise, if oil is red and all there, then your most likely problem is a lack of oil pressure, which could be (not usualy tho) a blocked cooler line, so you could try flushing the cooler lines, if that dont help, then it would be the pump in the transmission, or torque converter, hope i have been some help
    BF V6 Falcon
    Jun 2005
    Quote Originally Posted by Bilbs View Post
    Awesome man thanks for the advice
LinkBacks (?)
  1. Revs not Dropping On Gear Change - VY S Manual
    By VY5Speed in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-08-2014, 02:24 PM
  2. The speedo moves?
    By hispeedvp in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-10-2006, 09:58 PM
  3. Car moves to left
    By G4orce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-12-2005, 10:15 PM
  4. Vn drivers seat moves
    By BeaversVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-08-2005, 01:15 AM
  5. Tranny jumpin out of gear
    By El Hombre in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-04-2005, 03:56 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742 743 744 745 746 747 748 749 750 751 752 753 754 755 756 757 758 759 760 761 762 763 764 765 766 767 768 769 770 771 772 773 774 775 776 777 778 779 780 781 782 783 784 785 786 787 788 789 790 791 792 793 794 795 796 797 798 799 800 801 802 803 804 805 806 807 808 809 810 811 812 813 814 815 816 817 818 819 820 821 822 823 824 825 826 827 828 829 830 831 832 833 834 835 836 837 838 839 840 841 842 843 844 845 846 847 848 849 850 851 852 853 854 855 856 857 858 859 860 861 862 863 864 865 866 867 868 869 870 871 872 873 874 875 876 877 878 879 880 881 882 883 884 885 886 887 888 889 890 891 892 893 894 895 896 897 898 899 900 901 902 903 904 905 906 907 908 909 910 911 912 913 914 915 916 917 918 919 920 921 922 923 924 925 926 927 928 929 930 931 932 933 934 935 936 937 938 939 940 941 942 943 944 945
