Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: Cranking but Not Firing
    '97 VS Commodore + '98 E36
    Apr 2005
    Default Cranking but Not Firing
    My 97 VS has got 175 xxx k's on it, i filled up before i left for a long drive last night from sydney to wollongong (1hr 30mins) and then back again with no problems what so ever with half a tank left
    This morning i had to drive to work, i cranked the engine but it would not fire at all and i noticed that the fuel pump was'nt making a whirring noise when the ignition was on reds.
    so before i go changing the fuel pump, is there anything i should thoroughly check??
    keeping in mind that i have checked:
    -Fuses
    -Relays
    -Gave the tank a bit of a beating
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Make sure you have power to your pump, if you have, it's a fair bet that the pump is kangaroo edward.
    Visit my Facebook page
    VRII Acclaim
    Jul 2005
    The trusty gregorys will run you through a full check of every component leading to the pump, there are a few, but I would be checking at power to the pump first as it is likely that is your problem. A quick way to test would be to give the bottom of the fuel tank a couple of good whacks with your hand right in the middle. Try and start the car. If fuel pump works this time your pump is buggered.
    Otherwise if you have a mutlimeter connect it to the larger connector and get someone to turn the ignition, not all the way, the click before starting. The fuel pump should prime during this stage. If you see 12V there, pump is buggered. If not fault is somewhere before and the gregorys would be the place to go.
    94 VR Statesman
    Aug 2006
    it sounds like the pump has had it but also check the CAS (Crank angle sensor) near the harmonic balancer this is also a common problem with it not starting
    dufus is offline Donating Member
    rickshaw
    Jun 2006
    Had the same problem with my car 6 months ago. It turned out the pump was stuffed and after replacing it, it fired right up.
    VS wagon SII
    Mar 2006
    I had a similar problem just this morning. Although the car was running fine for about 5 minutes up the road, then suddenly stalled. Tried restarting, giving it 30 mins, restart....nothing. RACV guy said it could be a split hose in the fuel tank. Got it towed to my mechanic, who ended up replacing the DFI module & the 3 coilpacks. Runs smooth as now, as you`d hope for $400.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd first check to see if there is spark - pull a lead off and stick an old plug in it, earth the plug and get someone to crank it over - if there is no spark then it ain't the fuel pump.
    Another check method is to remove or loosen either the fuel delivery or return hoses - if fuel spurts out the pump is OK (easy to do at the filter)
    Good Luck.
    Apr 2005
    Thanx for the help lads, came up with a conclusion, busted fuel pump.
    Had the NRMA come over for a second opinion:
    -Electrics were fine
    -Fuse and Realy were fine
    -Spark was fine (sprayed some 'start ya bastered' in the inlet)
    -Gave the tank a few whacks whilst cranking the engine, but no go.
    so yeah looks im gunna be getting it towed to the mechanics sometime, i'd fix it myself but i dont have that much time on my hands, plus i got towbar in the way so that can make things real difficult.
    How much have people paid for a new fuel pump these days? supply and fit??
    MY07 VE Calais V
    Sep 2005
    Gold Coast
    About $200 to $250 to supply and fit fuel pump. My last pump died after running a couple of tanks of that alcohol blended fuel...won't touch the stuff now just in case.
    rickshaw
    Jun 2006
    Quote Originally Posted by DJ Ice View Post
    That sounds about right, mine cost $200 fitted.
    VRII Acclaim
    Jul 2005
    Towbar doesnt make it any more difficult, but its not the nicest job. If you got the cash leave it for someone else and save yourself the hassles.
    Apr 2005
    If i had the time, i would've removed the towbar and dropped the tank to make the job just a lil easier, but the bolts that hold the towbar that are in the boot are not easy to get to because of my boot install.
    bu yeah anyways, ive booked it in for 2moro morning, i got quoted $275 supply and fit from an NRMA recommended repairer, they have the best rep around my area.
    going to have the tilt tray pick it up 2moro at 9am and i'll fill you's in when i get it back.
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    mine sometimes is cranking but not firing when warm but secon turn of key all good...
    200,xxx on clock
    Chirpstr's Avatar
    Sep 2007
    doesn't always do it when warm...this morning went to start and just kept on cranking and cranking...waited a few seconds and second turn of key all good...Maybe my pump aswell is cactus...Blocked strainer maybe?
  15. #15
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
  16. #16
    VRII Acclaim
    Jul 2005
    Quote Originally Posted by r_i_d_a_h View Post
    I dropped the tank without touching the towbar. And dropping the tank isnt always necessary. Just for info though, I understand and support your method. Wavez, as hako said. Probably not fuel pump related.
  17. #17
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by kopper69 View Post
    Heavy duty towbars extend to in front of the fuel tank behind the rear seat...light duty ones (under 1200KG) do not so it depends on why type of towbar you have fitted.
  18. #18
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Also the brand, over here we have a manufacturer that make a 1200kg towbar that has a brace that extends to the front of the tank.
  19. #19
    Apr 2005
    Yeah, with the tow bar i got, it goes under and extends to the front of the tank, it pretty much protects the tank from, bottoming out, big speed humps and steep driveways.
    Picked up the VS yesterday and now it starts everytime =D
    Should i just stick to one petrol servo? and stick to 1 kind of fuel?
    plus, mixing regular and premium does no good to the car right?
  20. #20
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The best way of avoiding fuel contamination is to buy fuel from a large service station that sells lots of fuel and has a high turnover. This means the fuel is always fresh. Smaller stations (not fuel company owned) sometimes buy fuel from "jobbers" who run private tankers....this fuel can sometimes be old or stale or otherwise contaminated.
    You can mix any fuel you like - the Ecotec engine which has knock sensors will adjust ignition timing etc to suit whatever fuel you use or mix.
  21. #21
    rickshaw
    Jun 2006
    Ive never had a problem and i mix regular and premium all the time, and I rarely go to the same petrol station twice in a row but i always make sure that i go to a large petrol station such as BP or Shell because i can trust their fuel alot more than the smaller petrol stations, especially given that i live in the country.
  22. #22
    Apr 2005
  23. #23
    rickshaw
    Jun 2006
    whats the go with this E10 fuel?
    i just noticed the other day at my local Caltex servo.
    E10 Fuel is unleaded petrol containing 10% ethanol
  24. #24
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Ethanol deterioates rubber, and has a tendancy to flush out all the crap too. But a 10% mix won't cause any problems that weren't already there. Later model cars are manufactured with ethanol friendly components, so a higher ethanol ratio will be coming down the track.
  25. #25
    Chirpstr's Avatar
    Sep 2007
    Quote Originally Posted by hako View Post
    Not the keyhead not making proper contact?
    If that is what it is how can it still crank and crank and crank? Got a new key head from Holden awhile about a year ago anyway...
    It seems like there is no fuel pump relay sometimes... like it just keeps on cranking...like what a CAS would do if its cactus...but don't mention that one because it new along with most other things fuel reg, injectors, oil pressure and so on...and so on...
    Fuel pump I'm thinking...could it be blocked a little somehow? Strainer?
    Takes about 1-2 secs to prime but it's not like I put my head out the window every time to hear it...Checked fuel pressure awhile ago and it seemed fine... Maybe I will check it again...
  1. Slow cranking VT
    By SLAF in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-07-2009, 08:41 AM
  2. 5L cranking time before firing
    By V85000i in forum General
    Last Post: 17-10-2007, 05:51 PM
  3. VR Slow cranking
    By CrazyDayz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-10-2007, 11:02 PM
  4. Tunes Cranking In Your Ride !!!
    By Insane_Metal_Man_666 in forum Car Audio
    Last Post: 26-01-2007, 02:36 PM
  5. VC SLE Wont Stop Cranking
    By pjdigital in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-04-2005, 08:51 PM
