Results 1 to 6 of 6
Thread: Code 81 - 2 - 3 Shift Control Solenoid 'B' Fault - Auto Transmission Only
    vs statesman 5 ltr
    Jan 2007
    Default Code 81 - 2 - 3 Shift Control Solenoid 'B' Fault - Auto Transmission Only
    how hard is this to fix anyone have any ideas pls its in a vs statesman v8
    VR Statesman V8
    Jun 2006
    Just had a very similar problem with my stato.
    Hey before I go any further, hows the varitronic steering? has that stopped too?
    Check fuse 12 if thats stopped and it should fix the trans too.
    Failing that pull the trans pan and Ohm check the solenoids, specs are in the workshop manual.
    Tim
    '94 VR Statesman V8
    Petrol/LPGas and Pod filter, Pacemaker Headers, 16x7 BSA 248 wheels
    '90 EA Falcon Wagon 3.9MPFI Petrol/Gas, Work car
    1923 T-Bucket (Hot-Rod) 6/71 Supercharged LT1 350 Chev, T350, Jag rear
    vs statesman 5 ltr
    Jan 2007
    had this replaces by shop and engine ligh keeps comming on had it back to shop 3 times and they say they reset comuter and it is fine for day or 2 then comes back on getting very anoyed with only hacving 3rd gear lol
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    vs statesman 5 ltr
    Jan 2007
    solenoid was replaced is there any way i can check the wiring myself befor send back to shop and waist more $$$
    VS Executive S2 3.8lt V6 Ecotec
    Nov 2008
    Melbourne, Vic
    recurring 2/3 shift solenoid fault
    Try this tread I had the same problem (2/3 kept going and it turned out the little electrical clip to the solenoid on the wiring harness had broken. If this is what happened to u it was probably caused by the mechanic being too rough as the wiring harness is quite fragile. Make them pay for replacement if that is whats wrong.
    Cheers hope the link helps.
  1. Code 83 - TCC PWM Solenoid Fault - Auto Transmission Only
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-03-2007, 01:37 PM
  2. 3-2 shift control solenoid
    By mish22 in forum General
    Last Post: 22-01-2007, 05:35 PM
  3. Code 68 - Transmission Component Slipping - Auto Transmission Only
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 05:14 PM
  4. Transmission fault code 85?
    By accentstencil in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2006, 01:09 PM
  5. VR V8 Auto stuck in 3rd Gear / fault Code 18
    By nix8860 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-03-2005, 03:11 AM
