Results 1 to 5 of 5
Thread: Spool In Irs
    94 vr ss
    Oct 2007
    Default Spool In Irs
    is it as easy to put a mini spool in a irs diff as it is with a solid and can u use the same spool
    VP 5L Calais
    Mar 2007
    S.A
    yeah the spools are the same and it is easier to do it in an IRS car, just undo the two cv shafts from the diff and hang them out the way, then support the diff with a jack, drain it and remove the rear cover (which holds the diff to the chassis, that's why you support it so it doesnt drop down) then knock the axels out, and undo the two side caps, they screw in so tou just need to make a tool to slot in the notches to unscrew it. NOW IT IS IMPORTANT TO COUNT THE TURNS EXACTLY UNTIL THE CAPS ARE FULLY OUT, then pull the diff centre out and pull to bits and remove the gears and fit the spool, reassemble it, then fit it back in, MAKING SURE YOU SCREW THE CAPS IN TO EXACTLY WHERE THEY WERE, then put it all back in reverse order and fill it up with oil and go do some circles.
    94 vr ss
    Oct 2007
    ok well i am putn a spool in my car i all ways thort thay wer very hard to park but i drove one and there not tnxs for that
    VP 5L Calais
    Mar 2007
    S.A
    nah, you barely know they are there. but one strange thing is when you put your car in Drive (if it's auto) or even in a manual if it is in Nuetral, and the car is rolling and the steering wheel is turned 3/4 or more to full lock, the car stops and wont move until you apply enough power to skip the inner wheel, funny i rekon.
    94 vr ss
    Oct 2007
    yeh i felt that when i drove the car
  1. spool or no spool.
    By Burnout_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-05-2007, 04:37 PM
  2. LSD to Spool
    By AirStrike in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-03-2007, 05:38 PM
  3. Spool or not?
    By mickaitken in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2006, 05:02 PM
  4. Spool/Mini-Spool VS LSD
    By Torquen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-06-2006, 08:14 PM
  5. FED UP!...spool me up
    By walesy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-09-2005, 12:42 AM
