Results 1 to 8 of 8
Thread: Cooling System Flush
    VS Executive V6 Auto
    Dec 2007
    Newcastle
    Default Cooling System Flush
    I'm finaly getting around to changing my coolant, radiator hoses and thermostat.
    In my manual (not a gregory's) it has flushing instructions using a compersor and stuff.
    I was hoping to use a hose to flush the system so if anyone could davise me on how to do this it would be great.
    Note: the coolant is pritty rust so I want to give it a very good flush.
    Thanks
    dufus is offline Donating Member
    rickshaw
    Jun 2006
    Dec 2007
    Newcastle
    Thanks great How To.
    One more quick question is there any merit to buying new radiator and heater hoses?
    rickshaw
    Jun 2006
    Quote Originally Posted by mcvk View Post
    Only if your current ones are in poor condition.
    Dec 2007
    Newcastle
    OK got every thing I need for the job.
    One of the reasons I'm changing my coolant is that it was a bit low the other day so I think I might have a slow leak. What I was thinking of doing was flushing the system changing the thermostat and radiator cap then filling it with water (not coolant) and getting the system pressure tested. Is this a good idea???
    Does anyone know if its possible to get a free pressure test and where to get it?
    VP Exec
    Jun 2005
    The water pump seal won't like running with plain water very much (the coolant is a lubricant for the seal) so, no it's not a good idea to run plain water. Why not get it pressure tested first? You can often spot leaks anyway, without the pressure test. The coolant will dry, leaving brown stains where it has leaked from.
    AttaBoy is offline WTF?!?!
    VS Acclaim V6
    May 2005
    rickshaw
    Jun 2006
    The tablets for the cooling system that you get from Holden are just crushed up walnut shells and they are added to block any minor leaks in the cooling system.
  1. How To Flush A V6 Cooling System
    By ChRiDDa in forum Holden Commodore How-To's
    Last Post: 08-04-2012, 10:51 PM
  2. Cooling System Flush How?
    By calais_304 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-05-2007, 12:40 PM
  3. Problems in VX after Cooling System Flush
    By Secki in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-07-2006, 03:13 PM
  4. how do you flush out cooling system on 5L?
    By jim898 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2006, 03:50 PM
  5. Seeking advice on cooling system flush
    By Scooter79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-09-2005, 10:17 AM
