VS_wagoon
- Oct 29, 2007
- 3
- 0
- 0
- VS S2 Executive Wagon
I have an Ecotec VS wagon, it's done 218,000kms. It's in great shape and been well maintained, but around 5 or 6 months ago it started doing something wierd, and it's gradually gotten worse.
It only does it when it's cold(on cold mornings it is really bad - it will vibrate and idle quite rough until the engine has warmed up a little) - on really hot days it hardly does it at all.
When driving I always take it easy until it's warmed up, but regardless of the revs, it makes a groaning noise that I can also feel a little bit through the floor of the car, which makes me think it may be something big.
The strange thing is the noise is louder when going over undulations on the road, on a flat bit of road it can't really be heard usually. The noise is related to the engine revs, ie it changes pitch with the revs. I had a brief chat with a transmission guy and he said it doesn't sound like the trans(as it shifts perfectly), but could be a mount for the engine or trans.
It doesn't do it AT ALL when the car is warm, even at high revs, high load, whatever.
Only other thing I can think of is the bottom end bearing, I do recall about 50,000 kays ago when I had a big service the mechanic said it's leaking and 'will need doing soon'.
I've bad experiences with just handing cars over to mechanics with vague descriptions of a problem, usually they end up replacing lots of different things before finding the problem!
I'm hoping this problem will be familiar to someone! At least if, on the off chance, it's something relatively simple I may be able to do it myself. (ie anything that takes less than one day from first turn of a spanner to test driving the car again!)
