Results 1 to 3 of 3
Thread: Gearbox stuck in high gear!
    VS execo
    Nov 2007
    Angry Gearbox stuck in high gear!
    hey guys
    well i just finished my engine rebuild today and found out that the memcal for the camshaft is faulty and does not work (check engine light always on and thermo fan always on, which means it gone) but cpu is still fine. while im waiting on the new one i left the faulty memcal in the cpu and went for a test run. i noticed that the gearbox was always in high gear and wouldn't shift up or down! and that the speedo does not work . could this be all related to the faulty memcal? its also a VS V6
    thanks
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    well the transmission sounds like its in limp home mode (always in 3rd) which could probably just be the memcal (they might have given you a manual memcal?).
    but the speedo shouldnt have anything to do with that, not that i can think of anyway.
    did you pull any of the error codes when the engine light came on to see what it was saying was wrong?
    if you dont know how...click here for a look.
    http://forums.justcommodores.com.au/...s-revised.html
    Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
    VS execo
    Nov 2007
    yeah i tried to get the error codes but because the memcal is gone it wont even store any codes. i tried an other chip (stock chip) which made it run worse and then got the code 12 which meant it was fine, but dident take it for a drive because it was misfiring and nearly stalling cause of the camshaft. i hope its the memcal. yeah its weird with the speedo aswell i dident touch anything to do with it!
  1. Stuck in 3rd gear
    By sno in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-03-2007, 06:08 PM
  2. Will a VS gearbox fit in a VR - gear ratios different?
    By Blakie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2006, 03:12 PM
  3. high idle speed in gear
    By Colin_Linz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-11-2005, 12:36 PM
  4. My Gear Change,Rpm Too High!
    By Kall911 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-09-2005, 08:06 AM
  5. VR V8 Auto stuck in 3rd Gear / fault Code 18
    By nix8860 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-03-2005, 03:11 AM
