I wanted to know if there was a Series 2 VS Clubsport 1997, that came out with the 5.7 litre motor or the 215i. We own one and i am trying to check it all out in New Zealand. the build number is 1374.can anyone help and let me know. I am aware that in 1997 they powered the GTS and Senator with the 215i motor.
scott.![]()
never heard of the clubby being a 215i only knew about the gts and senator
DVLHSV Stage 2 is Now in Operation
My VYII Clubsport http://forums.justcommodores.com.au/...clubsport.html
If this turns out to be a legitimately factory built 215i Clubsport then that's a rare piece of gear, as Reaper mentioned!
WTB: mulberry VN interior parts
Well we have one here, is there a way I can check it out with Holden by the VIN number. or the build number?
Call HSV with your Vin number and they will give you all the information you will need.
Reaper
https://reports.hsv.com.au/authenticate/
Try putting your VIN number in there and see what it tells ya.
Ive only ever heard of the 215i senators and GTS' though but would be mint if its legit!
any chance of a few pics?
anymore confirmation on this build guy's? i might have one also. was it a chevy block or stroker 308?
I Think after 4 years he has found out or doesn't care by now....
MY WEAPON: http://forums.justcommodores.com.au/...ng-10-psi.html
NEED 3.9 or 3.7 DIFF GEARS, PM ME IF YOU KNOW OF ANY
If it's not a factory, then it could have had a motor transplant, or a badges/covers swap.
As mentioned before there are different models for NZ, like a S/C Senator and so on so it would be a export keep if anything.
