Results 1 to 24 of 24
Thread: VR on superlows, need guards rolled?
    VR Executive
    Jan 2008
    Default VR on superlows, need guards rolled?
    Hey fellows,
    im getting superlow later this week and i was talking to my mechanic mate and he said i need to get my guards rolled. My mate said it is simple and an easly to do it yourself. I checked my car and the fronts have already been rolled and i just got to do the back ones. My question is, should i roll the bak guards myself or get it professional done???
    Any help would be great, cheers.
    UNKNOWN's Avatar
    UNKNOWN is offline DEFECTED
    95 VR SII BT1 5 Speed
    Jan 2008
    NW Adelaide
    Front ones are done like that from factory... Get a profesional to do it mate.
    Haydz's Avatar
    Haydz is online now Fasten your seatbelts
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    '97 VS Commodore + '98 E36
    Apr 2005
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
    depends what width tyre your running. if you get an adjustable panhard rod you can get away with up to 235 tyres without scrubbing. unless you have a full car load and hit a big bump or take a corner real hard then it will scrub even with rolled guards.
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    pedders suspension can do it 120 for the pair. anywhere else i could try??
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    Fronts should be fine. Only the back so thats $100-$120. I wouldn't bother. Have you got 245,255's or something?
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    Chirpstr's Avatar
    Sep 2007
    7.5's...? That's what I have no need to get your gaurds rolled. Maybe get a adjustable panhard rod.
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    and what would that do? its only when i have people in the back if there is no one there i wont get any scraping. but if there are people. it will scrape
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    adjustable panhard rod will allow you to recentre the diff, instead of it being offset to one side when lowered
    Chirpstr's Avatar
    Sep 2007
    KRUPTD is offline VN BT1 5L
    VN BT1 5L,5spd,LSD
    May 2007
    Griffith, N.S.W
  15. #15
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    lol ok then and what is the price on an adjustable panhard rod?
    would it still scrape though
  16. #16
    VX SS II 6.3L/M6
    May 2005
    i paid $185 for my adjustable panhard rod. You really need one of these if your going to ultra lows, but for ssl or sl its not crucial (but recommended).
  17. #17
    Apr 2005
  18. #18
    Summer-Sickness's Avatar
    Summer-Sickness is offline 2005 VZ EXEC
    05 VZ Executive
    Jan 2007
    Rockingham, Perth
    ive got a vr berlina on superlows with 18x8's and 235 tyres on em... didnt get the guards rolled n theres no probs at all.
    REHAB IS FOR QUITTERS!
    MY 2005 VZ EXECUTIVE
  19. #19
    lc torana. vn v8. ke30.mazda 1300.
    Mar 2006
    i mean for 120 bucks max to get your guards rolled its a pretty cheap safe guard just incase... most wheel and tire places can do it..
    and as mentiond the panhard rod is the go pick em up for under 200
    wrecking VL COMMODORE 5 speed
    FOR SALE : supra 5 speed box suite holden v8 $800
  20. #20
    UNKNOWN's Avatar
    Jan 2008
    NW Adelaide
    I just got a Pedders Adjustable pan hard rod for $70 at my local wreckers!
  21. #21
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    let us know how you go unkown.
    im still not sure because if i bet my guards rolled and they crack the paint im going to be very ****ed off. especially because i will then need a full respray.
    so if a panhard rod works. i will get one of them.
    also my mate said a panhard rod would make u use tyres more often because of camber wear. is this true?
    thanks for all the help.
  22. #22
    VX SS II 6.3L/M6
    May 2005
    Hey mate,
    Ill try to explain what the panhard rod does, and why you need to change it...
    Ok basically you've got the diff in the back which has the wheels connected to it. Now obviously you cant bolt the diff to the body/chassis as you would have no suspension...
    So you put suspension springs between the body/chassis and the diff... So basically the diff bumps around when you hit bumps.
    Now if you can imagine the body sitting on some springs which are connected to the diff, there is nothing actually stopping the diff from moving side to side...
    So you have a panhard rod connected from one side of the diff, the the body of the car on the opposite side.
    If you've ever seen the V8s you may have seen when they break a panhard rod... and you can see the wheels moving side to side under the car. thats what happens with no panhard rod.
  23. #23
    UNKNOWN's Avatar
    Jan 2008
    NW Adelaide
    Quote Originally Posted by Haydz View Post
    I have my gaurds rolled aswell as a pan hard rod, got the gaurds done profesionaly and diddnt have a problem with paint cracking.
    Also, I have 19s with 245's on them, no scrubing at all..... Not even with a full car load.
  24. #24
    Chirpstr's Avatar
    Sep 2007
    Good diagram feistl, hahaha I like the springs LOL. I'm not tearing you, I just like the way to draw. Does explain it well, nice work.
  1. Car rolled backwards while in 1st gear..
    By VRSS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-02-2008, 12:45 AM
  2. Rolled gaurds..?
    By m0zzaVP in forum General
    Last Post: 22-01-2008, 05:52 PM
  3. rolled guards ???
    By silver_bullet in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-03-2007, 10:49 PM
  4. Lipped or Rolled?
    By VL Berlina 5speed in forum General
    Last Post: 16-11-2006, 03:14 PM
  5. Rolled Guards
    By nvs_sle in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-08-2006, 06:19 PM
