Results 1 to 10 of 10
Thread: removal of plastic above Radio/AC Surround plastic
    '94 VR Commodore Executive
    May 2006
    Adelaide, Australia
    Exclamation removal of plastic above Radio/AC Surround plastic
    hi all,
    was wondering if anyone knew had to remove the plastic surround from above the radio/Air-Con. I'm trying to paint my interior and can't get the A/C to come out or move so l can pull out the plastic.
    I'd apprechiate all suggestions.
    Attached Thumbnails Attached Thumbnails removal of plastic above Radio/AC Surround plastic-how.jpg
    See My Ride: VR
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    Pull out shifter surround by lifting from the handbrake end, it only clips in, then pull backwards slightly and it's off. to get it over the shifter is just a matter of holding it on the right angle and wiggling it a little.
    remove the glovebox by opening it and pulling the drivers side pin, it should just fall on your feet then.
    drop the fusebox cover and pull passenger side pin, again it'll just fall.
    down the sides of the console surround are 3 screws, pull these out.
    there are 2 (I think) screws on the bottom, and another 3 on top.
    getting the surround out takes a bit of effort, wiggling and swearing as it clips into the centre console by tongue and groove style joins
    May 2006
    Adelaide, Australia
    l got as far as taking the screws out and trying to wiggle it out ( l had the console out at the time) but that little white bit that's on the back of the AC keeps getting stuck!
    See My Ride: VR
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    the surround itself you want to remove is a ticky one,
    You will need to take out the glove box, and drop the fuse panel cover. Then you will need to undo the screws on the sides as well.
    Goodluck.
    ashbox's Avatar
    ashbox is offline back in black
    something black
    Apr 2007
    The Car
    are you talking about the back part of the a/c unit, cos if you are it should be held in by a screw.
    Chev badges are an instant fail
    May 2006
    Adelaide, Australia
    no, l've got all the screws out and the surround is loose but l just can't get it over. it's all good. l'll have a go tomorrow. see how l go!
    See My Ride: VR
    VR EXEC
    Dec 2005
    quarantine
    Quote Originally Posted by jayderichards View Post
    try disconnecting the heater control rod. sorry, should have mentioned that. it's in the drivers footwell, tucked up under the console above hte trans tunnel. stick your head under there and look for a metal rod running from the back of the ac controller to a white plastic clip roughly level with the footrest (but higher)
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
  8. Default
    the worst part when you have disconnected that rod is then the vacuum hoses. argh. good luck
    Quote Originally Posted by zai View Post
    I am not sutpid
    VR EXEC
    Dec 2005
    quarantine
    nah dude they just slip off and they only go back on one way from memory
    May 2006
    Adelaide, Australia
    awesome guys thanks! i was just about to post about that metal rod! Hopefully It should come out now.
    See My Ride: VR
  1. plastic gear surround?
    By vn calais manual in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-01-2008, 06:26 PM
  2. VX Wheel Arch Removal - Plastic Screws
    By NeilD in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-09-2006, 06:18 PM
  3. Colour is falling off from dash plastic surround...?..
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-12-2005, 04:29 PM
  4. VY plastic dash surround
    By NightShadow in forum Car Audio
    Last Post: 07-10-2005, 12:46 PM
  5. Plastic Antenna Surround on Guard
    By TheJackal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-01-2005, 09:26 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
