I have a VS Acclaim sedan with stock 205/65 15 wheels and tyres.
As the tyres need to be replaced, I thought it would be a good time to upgrade the wheels as well.
I have seen a few on ebay (VY and VZ alloys with good tyres) but am not sure if they will be OK on the VS.
Apparently the stud pattern is the same, but I gather there are differences with the hub size and wheel offset. Not sure if these differences are significant.
I don't want to buy them off ebay and then find they don't fit or will affect insurance.
Any advice would be appreciated.
Thanks![]()
Should be fine mate. Im running 18" VY SS rims on my VR wagon, only time you might have issues is if your trying to run 19/20"s on ultra low suspension![]()
any commodore wheels are interchangable from VB-VZ with no problem. the VE wheels will also fit but not safely.
The Hub and offset you talk about won't affect VT-VZ 15-18" wheels on a VS.
Only 19 + 20" wheels sometimes cause problems.
Although the Hub size is different (front only) for the brake discs between VN-S (70mm)to the VT-Z (71.5mm), the part the wheel sits on is the same 70mm for both cars.
VS wheels have a 43P offset standard and 40P offset for HSV 8" wide wheels.
VT-VZ wheels all have a 48P offset and all fit fine.
SW
HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
Thanks guys, now all I have to do is win one of these auctions !
Glad to help.
