Temporary fix
To lighten the load on the power steering pump and rack consider the following:
- Make sure the power steering fluid is full (consider changing it if its looking mucky, this can put new life into old units).
- Higher tyre pressures on the front wheels, this reduces the load on the power steering system but with other drawbacks such as a rougher ride. When i say higher I mean at or slightly above the rated pressrue of the tyre (make sure you fill the tyre when its cold and not after you have been driving all day).
-Dont take the wheel to full lock, it sounds nastly when you do it so just dont, its not nice!
