If you have alook underthe car you will see the handbrake cable( easy to follow from the rear wheels back)
Follow the cable from one side till you see where it meeets up with the other side in Y type formation (meets with other side a cable from handbrake lever).
At this point you will see a adjuster (think its a 10mm spanner JOb from memory)
If you turn this bolt one way it will tighten the cable and turning the opposite way will loosen the cable.
This is where you do the adjusting from. Just give it a few turns then check handbrake lever. And if you need more turn it some more. I think from memory 3-5 clicks is what they check for when doing a roadworthy.
dont forget the rear locking nut, its12-13 mm, or 1/2' depending which employment agency is being used, tightening cabled is short gap,it will only leave drag on pads, and then your pads ending up welding to disks, get a 10 mm ring spanner and adjust it up at the wheels until each one just starts to give a scrape sound,then back off the 10mm 1 turn. AFTER YOU BACK OF THE Y PIECE CORECTLY DESCRIBED BY previose gentleman, if it has to be pulled up a long way, some one been driving with handbrake op, if you in perth, i will adjust as per requirements, not Mr Vb or Mr bonger. I take pride in my brakes, if you choose to, you need a least 1 full bottle of fluid, to flush last years black crap from soft rubbers. I am just fussy, but its your car, if you want it done well and cheap, as i need the money for chev parts , you need brake parts to stop, email me today
[email protected] no skin off my nose, but when people ask for advise and help, i give it, but I also got bills, and what i charge you wouldn't even feel. If you can spare 1-2 hours while you wait, I can do it here or at families workshop, am not fishing for work, I turn down crap, and a lot of times don't get paid cause i help out welfare scum who blow their money on pot and **** instead of replacing th money I spend on parts, so now I must ask customer to buy his own, ifloal at Repco, I will go with you to ensure the price is truely trade, which I dont benefit from this order to them and get them at trade price. Yours respectfully, And I dont have evry man and hid dog knocking on door, just those who look like being ripped off, come see, if you dont like my work, say **** off, and no loss to you or me,
RING AFTER 11AM or no answer, 94983450
Jim Richards.
Custom Engineering,
ps have VP alternator, vl alternator near new and recond dizzy for vl, in case you know some one. Vp alt, $20.00 VL $100.00, VL recond dizzy $100.00 and dash and stuff, anyway, if you want brakes donr txt me on 0406712592, if it fails, cheap import crap, then email me on
[email protected] or email
[email protected] NO CREDIT, NO CASH NO CODE 31
