Hey all, quick question, I’m almost 100% sure that one of my sensors is going because the electrical warning light comes on while driving around it happens about 2 times in 500k and i cleaned the battery terminals re crimped the alternator positive (not sure if that would do jack) and i am pretty sure its not the maf or sensor on the airbox because she is idling fine i was thinking maybe there s the o2 exhaust or somthing something quick and easy to change
i have though about taking it in to put it on the computer but it happens so rarely and in inopportune times and I’m pretty sure they have to turn the car off to hook her up which resets the sensor anyway so it works fine again
any info would be appreciated
its a chiped vs 3.8
Anything worth shooting is worth shooting twice. Ammo is cheap. Life is expensive.
If the battery warning light is coming on intermittently it's most likely to be worn brushes on the voltage regulator (or even a faulty regulator). When that light is coming on the alternator is no longer recharging your battery. To fix it disconnect the battery (very important!!), remove the alternator and then unscrew the regulator from the rear of the alternator. Check your brush length - from memory 4mm is the minimum travel allowed. Mine started failing at only 7mm but it's a simple and cheap fix to eliminate.
Mark.
awsom ill have a look and report back
thanks for your help mark
if you can use a soldering iron you can replace the brushes in your old regulator this will save you alot of money i was told by sprint auto it couldnt be done but i did this in my VR the cost for a new regulator was $35 but i bought the brushes only for $6.50 a huge saving the part number is GB610 and there bosch hope this helps
cool ill let you know how it goes this weekendcheers guys
ok mabey next weekend my alternator is more special then i thought the reg is 275 dollars last of the boch........
brush kit 35 and inbound 4 days
wacked em on the light has not returned yet!
the brush lenth wass good however they where nto solderd fantasticly.
with no pressure on them one was shorter then the other but only by a few mill hipe has done the trick, now all i have to fix is the cnetral locking :P
thanks for all your help guys:P
