+ Reply to Thread
Results 1 to 3 of 3
Thread: Not firing
    Vr Exc 1994
    Sep 2005
    Sunshine Coast QLD
    Default Not firing
    Hey guys...sometimes when i turn my key in my ignition nothing happens...The accessories will come on...but the engine wont do anything....but when i clock the gear into Neutral it works... somethings even then its a few turns b4 anything happends....
    anyone know why this would be?
    thanks guys
    Vr S11 exc
    Drifting in a front wheel drive, is like going to maccas for an apple, Possible but pointless
    '97 VS Commodore + '98 E36
    Apr 2005
    Most likley the inhibitor/neutral switch is rooted, common problem with the Auto VN-VS.
    Just lift out the centre plastic piece that surrounds the auto selector and grab a screw driver to remove the white plastic pieces around the gear selector then you will see the inhibitor switch.
    Just go down to the wreckers and get a replacement...$5-$10??
    had the same problem with mine...but i used it as a kill switch kind of thing
    looks similar to this
    Vr Exc 1994
    Sep 2005
    Sunshine Coast QLD
    Ah cheers man! thanks for that! will def take a look
+ Reply to Thread
  1. Firing Order V6 VR
    By patullose in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-12-2009, 09:49 PM
  2. Firing on ony 4 or five cyl's
    By dinodog in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-10-2006, 08:29 AM
  3. VK 202 firing order?
    By scott's ass in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-08-2006, 09:28 PM
  4. Miss Firing!!!
    By hold-on in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-05-2006, 01:44 PM
  5. VP Keeps tickin over but not firing, even when key is out!
    By VP2NV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-10-2004, 07:43 PM
