Results 1 to 6 of 6
Thread: Water Leak
    VR2 Exec
    Jun 2005
    Default Water Leak
    Hey all, i've got a pretty nasty looking water leak coming from the front of my vr v6, water seems to be dripping off the timing cover down onto the sump, i suspect the water pump seal is shot, but the pump cover seems to be dry. All the hoses are fine. Any ideas? I dont think it could be anything but the water pump... It also has milky crap throughout the cooling system. Which i may or may not look into later...
    Nathan
    AttaBoy is offline WTF?!?!
    VS Acclaim V6
    May 2005
    The milky crap in the cooling system does not sound good. Normally it occurs when oil is mixed with coolant. Some how oils is entering the cooling system somewhere or that you have a blown head gasket. It may not relate to the leak you have but I'd check it straight away.
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Welsh plugs, intake manifold gasket has split, tighten the rings around the hose ends to be 100% sure. Just have a really good look around, as sometimes coolant can leak, then run down the block in different places and then drip onto the ground from a totally different spot. Get a bright torch and look in every possible place you can.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Sounds like the water pump leaking - it will leak from under the pump where there is a bleed hole for that purpose visible only from under the pump. The milky crap may just be soluble oil or Barrs Leaks or similar which has been added to stop the leak from the water pump. If the car is otherwise running fine I'd not worry about the possibility of a head gasket blown till later if at all.
    VR2 Exec
    Jun 2005
    Replaced the water pump, leak fixed but now the radiator cap leaks, new radiator cap fitted, now takes forever to warm up! Now to find out whats wrong with the trans...
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Sounds like you might need a new thermostat as well. Did you replace the coolant when you replaced the water pump? Did you use the right concentration (50:50) of a good ethylene glycol coolant or the cheap coloured water variety?
  1. water leak
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-04-2008, 10:08 PM
  2. water leak
    By andyman in forum The Pub
    Last Post: 21-08-2006, 04:36 PM
  3. water leak
    By scotto in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-01-2006, 06:25 PM
  4. Water leak
    By Emu in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-08-2005, 12:24 AM
  5. VN water leak
    By NORTI in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-09-2004, 12:03 AM
