Results 1 to 3 of 3
Thread: 3 window dash cluster
    supercharged_vs Guest
    Default 3 window dash cluster
    I am looking at buying a 3 window dash cluster and trip computer for my VS ute "96". Just want to know before I go and buy it, will these plug up to my existing wiring harness, if i currently have speed alert. If not, what other things do I need. Am I going to run into any other troubles???
    Please Help!!!!
    Fekason is offline Fekason
    MY11 VE Series II SV6 Manual
    Mar 2005
    Penrith NSW
    Default VS Upgrade to Level 3 Cluster
    Hi,
    It can be done, but it is not a straight swap.
    The wiring for the trip computer will not be there.
    You will need to source a wiring harness from a Berlina/Calais/Statesman, and make a patch harness for the connector 4 on the cluster.
    Only clusters from VR/VS are suitable.
    I finished mine two days ago, and am totally pleased with the outcome.
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    It has been discussed many times on this forum....clickhere and you will find plenty of info about the conversion.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  1. 3 window cluster
    By omar302 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 20-12-2007, 04:49 PM
  2. 1 window dash cluster to a 3 window?
    By Youngblood in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-04-2007, 09:45 AM
  3. Swapping VR L2 dash cluster with VS Stato L3 Cluster
    By wheredoesthisgo in forum Electrical Wiring / Questions
    Last Post: 07-04-2007, 03:28 PM
  4. Replacing 1 window cluster with a 3 window
    By dusted in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-03-2006, 03:25 PM
  5. Replace VN dash cluster with VX dash cluster
    By Xalies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2005, 06:55 PM
