Results 1 to 11 of 11
Thread: vs v6 tranny gone?
    MY10 SSV UTE
    Dec 2006
    Melb
    Default vs v6 tranny gone?
    mates got a 97 vs 11, other night his missus was driving to work she went to do a u-turn and car lost its balls.
    had a drive of it 2day and seems like tranny problems, go to take off from idle and just revs for awhile then SLOWLY starts moving only really struggles on take off and low speeds, any ideas?
    cheers
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The most obvious question is, have you checked the fluid level or the condition (colour) of the fluid?
    Sorry if you think this is a dumb question but I have no idea how knowledgeable you are about transmissions.
    MY RIDE
    MY10 SSV UTE
    Dec 2006
    Melb
    Default .....
    yer fluid seems fine but am gona service the tranny 2day, see how we go.
    91 VP 5.0 V8
    Nov 2006
    Sydney,nsw
    MY10 SSV UTE
    Dec 2006
    Melb
    Default ...
    no luck with the service still the same maybe slightly better,
    has this happened to anyone before how was it fixed?
    from standing start from red lights etc, it just revs and slowly gets movin takes awhile?
    MY10 SSV UTE
    Dec 2006
    Melb
    Default ...
    how much oil should be put in after dropping the pan regardless of what was in there because it mightve been abit low,
    how much should come out and go back in?
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    who serviced ur trans? what color is the fuild? dark red or crimson?
    Have you checked your error codes to see if its something major?
    MY10 SSV UTE
    Dec 2006
    Melb
    Default ...
    me and a mate did, fluid was probly a dark red, havent checked codes, no lights have came up
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by lumina01 View Post
    Don't worry about how much comes out and goes in, use the markings on the dipstick to determine the correct amount. Around 4.8 litres should go in if you empty the pan.
    MY RIDE
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    id be checking your error codes just to make sure that everything is running ok, may still have logged a code with out the light.
    vs series 2 executive commodore wagon
    Jun 2008
    I did have a problem with my vs with only 28000 km on it.The car had no first gear it was taking off in second gear.The problem was a solinoid in the gear box worth around $60 dollars.I had it replaced quickly as not to do to much damage to transmittion.This did come up with a fault code on dash.I dont know if this will help.
  1. VS tranny fit VR??
    By jayignorantz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2007, 12:55 PM
  2. vl tranny into vk
    By commo69 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-04-2007, 07:22 PM
  3. Tranny on the way out?
    By VNCalais98K in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-10-2006, 09:55 PM
  4. Which tranny for my VK
    By HSVbenno82 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-08-2005, 02:42 PM
  5. tranny
    By freddy69er in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2005, 12:05 AM
