Results 1 to 10 of 10
Thread: trans fluid colour.
    91 VP 5.0 V8
    Nov 2006
    Sydney,nsw
    Default trans fluid colour.
    whats everyones opinion on the colour of this fluid?.going by the clour you think the trans is on its way out or could it just do with a service?.dont know if the pic is clear enough but the colour is like clean/new engine oil.
    VSII Berlina
    Dec 2005
    SA Nth/Est
    VT Berlina & mazda 2 DE
    Jul 2006
    Ohh man she is due for a-changin. Tranny is probably ok- I have seen worse. The biggest telltale is if the oil smells 'burned', and when you drop the pan if there are solid particles in the bottom
    91 VP 5.0 V8
    Nov 2006
    Sydney,nsw
    thanks,fluid doesnt smell to bad compared to new stuff,maybe a little "burnt" if anything,also could this be a possible reason why im getting a 24 error code?.if its starting to slip a little?.what you think the chances are of saving the box with a service,might be a long shot asking but doesnt matter.
    Jul 2006
    I believe chances are fairly good, change ALL the oil- take the line out (to the radiator tank) off and pump it out, if you can afford the fluid do it twice. Ensure the filter is changed. should greatly improve.
    91 VP 5.0 V8
    Nov 2006
    Sydney,nsw
    Jul 2006
    Service capacity is listed at 4.8 litres, I would be pretty sure though that the whole system would hold something like 10 litres (anyone?) I usually buy a 20 litre pail for a big service.
    2005 VZ Exec - 95 VS Executive
    Jan 2007
    if i rememeber correctly dry service is like 7.9ish litres, i was reading my book about it last night.... or was that engine oil i was reading... hmm lol
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    She'll be right mate. Whack some red food dye in there. lol
    Nar drop the pan drain the fluid out of it, change gasket and filter while your there. If you panicing about it take for a 30km drive then drop the pan again but keep the filter and gasket.
    Or alternatively you could just disconnect it from the radiator but this will never get all the fluid out of the torq converter...neither will dropping the pan, trust me I tried it. Make sure when the fluid starts to slow down switch it off cause it can hurt the pump. Then top it up and do it again. But you can be there for hours filling it up and draining it from radiator and waste allot of money, time and energy waiting for the nice red colour to come through. You'll just have to be happy with it at some stage.
    All the best mate.
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by ragrim View Post
    7.9lt dry fill is correct.
    MY RIDE
  1. Water in with the trans fluid!
    By JD in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-10-2007, 07:35 PM
  2. auto trans fluid loss
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-01-2007, 08:16 AM
  3. auto trans fluid leak
    By jenzee in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-04-2006, 06:12 PM
  4. Brake Fluid and Auto Trans Fluid.
    By Melchior3 in forum General
    Last Post: 20-02-2006, 11:49 AM
  5. Unexplained Leaking Of Trans/ps Fluid
    By ML3 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2004, 04:41 PM
