Results 1 to 12 of 12
Thread: 94 VR Engine Problems
    VZ Executive s1
    Jun 2008
    Default 94 VR Engine Problems
    i have a Auto 94 VR and when i try and go fast in it, the engines revs will complety drop when i hit 4500 revs or when i hit kick down and a light will flash on, im not sure which light it is as it happens very quickly, the engine revs will come back as quick as it happens but if u keep ur foot down it will keep doing it. this is a bad problem when i try and go up hills and when it drops down the gear
    does any1 know what the problem is????
    vp berlina lx
    Jan 2008
    melbourne vic
    not sure really it could be something to do with the gears in the auto like it may be slipping under pressure your probly best taking it to a mechanic dude
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Its not just a bad miss. How do you mean the revs drop, does the car loose power and the tacho drops or does the car bog down and slow up
    Reaper
    VZ Executive s1
    Jun 2008
    the car complety losses power and the revs drop to 0 but the engine stays on
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    May I suggest explaining the symptoms better because its kind of hard understanding what your trying to say. Go and have a look that light flashes when it does it next time, this will help us.
    VrWagz1's Avatar
    May 2008
    wollongong
    Could be just some dodgy spark plug leads shorting out, but if your getting a light on too we need to know that too. Like Mack said, give us a better description of exactly whats going on.
    Reaper
    VX SS II 6.3L/M6
    May 2005
    vp berlina lx
    Jan 2008
    melbourne vic
    like vrwagz1 said it very well could be a spark plug problem i remember a while ago one of the leads on my car was on the wrong plug by mistake and that caused it to go ****ed similar to what you said so maybe check your plugs/leads
    VZ Executive s1
    Jun 2008
    i checked the light and it is the engine light that is flashing on
    does any1 know the firing order for VR v6 from coil to spark plug???
    vs series II equipe
    Sep 2005
    You need to check the error codes to give a better idea of the problem. When was the last time you changed the spark plugs?
    VZ Executive s1
    Jun 2008
    the error code is 44 it is the oxygen sensor i think i have taken it out and cleaned it but it didnt do anything
    i have had a engine change over so all the plugs and leads are new
    VrWagz1's Avatar
    May 2008
    wollongong
    Have you got new one and tried it or swapped with a mates one, to see if it clears the fault. If not start checking and metering the wiring.
    Reaper
  1. Engine Problems
    By Holmez in forum V8 Development and Modification
    Last Post: 10-10-2007, 12:25 PM
  2. engine problems
    By andrewgrazier in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-07-2006, 08:32 AM
  3. VS V6 Engine Problems
    By Rusty's VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2006, 12:51 AM
  4. 253 engine problems
    By src308 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-02-2006, 07:54 PM
  5. Help VS engine problems
    By seabass in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-10-2005, 07:31 PM
