Results 1 to 5 of 5
Thread: disc rotors
    vn vacationer auto v6 sedan
    Jan 2006
    Default disc rotors
    G'day , the vs2 that i have just purchased has had the brake update to vt , but the car has a shuddering when lighly applying the brakes , if you push hard enough on the pedal it almost goes away , no probs just driving along. is it a big job to remove them to get machined ? , i have done a few before but none with ABS so i am a little worried about it , the car stops fine , just the shudder p!@#$s me off , and it would save me $ if i can take them off/replace them myself , thanks.........
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    removing rotors will not effect the ABS as it is mounted inside the hub.
    Body by Holden, Soul by Brock
    the Legend will live forever
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    once the wheel is off it takes about 2 minutes to get the discs off. Just undo the two caliper bolts and it will slide off. When doing to rear make sure you have the handbrake released or you wont be able to slide the rotor off. I have been quoted at $40 to machine front rotors at my local ABS brake shop.
    IMO i would replace the standard rotors. Have a look around here and you will find slotted rotors for ~ $140 a pair which is a great price and they will improve brake performance etc.
    Good luck with the shudder
    EDIT: remember to put some locktite on those brake caliper bolts when you put them back in.
    no longer a hoon by association - the commodore is gone
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I do the standard rotors for $90 a pair and slotted for $135.
    Machining isn't always successful on floating rotors. (Held on by the wheel).
    Visit my Facebook page
    Apr 2006
    Auckland NZ
    i don't like machining rotors, less material means less time before brake fade sets in. slotted rotors all the way. stock VT rotors are well known for warping. my old boss went through a couple of sets on his VT before he sold it.
  1. RDA Standard & High Performance Disc Rotors
    By gslrallysport in forum GSL RallySport
    Last Post: 16-02-2012, 11:20 AM
  2. brake pads and disc rotors
    By damo15 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-06-2009, 07:31 PM
  3. Disc Brake rotors?
    By westic in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2008, 08:03 PM
  4. Replies: 2
    Last Post: 01-02-2007, 11:12 AM
  5. washing car after long run(hot disc rotors)
    By justbad4you in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-10-2005, 07:34 PM
