Results 1 to 5 of 5
Thread: Oil flush and pwr steering leak.
    Burniehoon's Avatar
    Burniehoon is offline VR 4 Life
    1994 VR Series I
    Apr 2008
    Burnie Tasmania
    Default Oil flush and pwr steering leak.
    Ok first up i have a fairly decent leak in my power steering i checked the level this morning and it was all the way at the bottom of the dipstick and you can see where it has been leaking over time. So my question is can this be fixed or will i need to replace the whole unit. Also when i turn it does make some noise, does this mean it's worn out or can a flush fix this.
    My second question is should i do an oil flush. I'm not to sure if the car has ever had one or not but i was thinking about doing one this week when i give it a service. People have said that it can cause blockages and do more harm than good is this true? also what is involved with an oil flush? and any specific brands i should use?
    big m's Avatar
    big m is offline FIGJAM
    vslll v6 2000 olympic series ute, 1997 pajero 3.5l
    Sep 2006
    nsw
    hey burnie firstly where abouts is it leaking from this will depend on wether you can fix or hae to replace anything and secondly the noise is most likely you p/s running low on oil top it up and then turn the wheel for a while and see if the level drops because it will have air in the lines that is if it is low in oil,
    about flushing your oil not to sure about anything on that all i ever do with a service is old stuff out new stuff in lol
    anyway hope that answers your question mate.
    Homer: "for once in my life someone is calling me sir without (your making a scene)"
    Burniehoon's Avatar
    1994 VR Series I
    Apr 2008
    Burnie Tasmania
    Thanks for the reply mate i'm not 100% sure where the leak is coming from um know of any easy ways that would help me find it?
    big m's Avatar
    Sep 2006
    nsw
    yea mate get a can of degreaser or 2 and give it heaps spray everywere hose and as soon as you stop driving it have a close look at all the seals all the lines everyplace itis connected to powersteering and you should fine the leak
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    the power steering leak is probably the pump, its common as hell. do yourself a favour and get a seal kit for the pump and new lines from the reservoir to the pump and also check the high pressure return lines for leaks.
    getting your car up on a hoist should reveal pretty quick where its leaking - if not, degrease completely, drive for a day or two then put it back on the hoist to track down the leak (most likely going to be the pump).
    i wouldnt worry about an oil flush - just change the oil & filter at regular service intervals and it'll be fine.
    Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
  1. VN power steering leak
    By timmy_tam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-10-2008, 05:21 PM
  2. power steering leak
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-12-2006, 09:59 PM
  3. another vt steering leak
    By scozzman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-12-2005, 08:46 AM
  4. Power steering leak?
    By Sons1vn2nv in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-10-2005, 11:03 PM
  5. steering leak
    By Barfly in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-07-2005, 09:58 AM
