Results 1 to 7 of 7
Thread: Strange cooling problem
    VZ Calais
    Aug 2005
    Mackay Qld
    Default Strange cooling problem
    After about 10mins of driving, the temp gauge hits 3/4, the dash warning light & siren go off, then the temp returns to normal & all is good!
    VS Caprice, eco.
    Anyone have an idea?
    Cheers, Col.
    vsiicalais's Avatar
    vsiicalais is offline Donating Member
    VEII Thunder SV6
    Aug 2007
    Warragul
    could be a faulty thermostat or a possible partial blockage of one of the pipes but im guessing its more a faulty thermostat
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'm with littlegeorgy01 - thermostat sticking when cold then once forced open behaves normally.
    VZ Calais
    Aug 2005
    Mackay Qld
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    Failing that, your temperature SENDER (the one that controls what is shown on the dash) could be faulty too. When the gauge is showing 3/4 is the cooling fan coming on? If so, does the temperature drop down again?
    VZ Calais
    Aug 2005
    Mackay Qld
    VZ Calais
    Aug 2005
    Mackay Qld
    Update.
    Loosing coolant. No visable leaks.
    I took the rad cap off & started the engine, when the thermostat opens there is a steady stream of bubbles!
    The heads are coming off next weekend!
    Car has 105000ks, it sat in storage for 3yrs before i bought it.
    Looks like it didn't like the rest!
  1. Cooling problem
    By ben_skipp in forum General
    Last Post: 12-06-2008, 09:57 PM
  2. Cooling problem. maybe.
    By VNCalais98K in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2007, 11:00 PM
  3. Strange, strange problem.
    By Morton in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2007, 05:26 AM
  4. Cooling problem!
    By Famine in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2006, 08:12 AM
  5. VT cooling problem. help?
    By VT SV6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-07-2005, 12:51 AM
