has anyone fitted a Bosch 040 pump into a VR/VS sedan tank? From a quick look it looks like the opening has to be cut out.
Can anyone whos done it before post up any tips or pics?
ive got one in. Walbro GSS 342 is a similar pump too. the pump carrier needs to be trimmed a bit and a little rewiring. thats about it. They are noisey as hell though!.. well mine and my mates (R32 skyline) are.
No pics here tho sorry.
Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
cheers, what did you have to do to fit it into the tank? does it hit on the bottom of the tank.
The pumps should physically be the same size (stock & Bosch). If you are having trouble manouvering it into the tank, its prob best to drain some of the fuel out and drop the tank out (or down at least..)
if you fit it correctly, no, it doesnt hit the bottom of the tank. It should fit in identically to the position of the original pump.
the bosch 040 is alot larger than the stock
Installing A Bosch 040 Fuel Pump Into An R32 - Skylines Australia
i managed to make it fit in alright, as i said some mods will need to be made to the pump carrier. The tightest spot is when manouvering it assembly into the tank (hole)
