I looked at the oxygen sensor and found it had four wires 1 wHite 1 purple and 2 salmon/pink wires do I cut both salmon pink wires or what?
Why? Are you having problems? If you are getting a no signal error from the RH sensor, then it's the purple wire you cut, if you aren't, leave it alone.
there are two black wires, a violet & a pink wire.
cut the pink one, its the power to the heater circuit
the violet one is the signal wire & the black ones are earth.
to make sure you have the correct one check it for battery voltage when the ignition is on
Oops, buggered that up, I thought it was the purple one. (from memory...I'm tired).
Here pics of the ones I got from holden.
Sorry for the silly question just checking?
Looking at the first pic is the top wire the pink?
Just the bottom two don`t look black to me.
"Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
My VS II Berlina Wagon
MY12 II SV6 Sportwagon
The correct colour wires are in the car loom, not the O2 sensor. Look at the colours of the wires on the other side of the plug.
Thanks mate that makes more sense how![]()
Ok one last thing why is a heater connection going down to the oxygen sensor?????., I can`t think of any reason!!!
The sensor has a heater.Not the heater that warms up the cabin
Oh.. to bring the sensor to the operating temp faster, 300+ degrees if I remember correctly.. fancy, my VR 5.0 dosen`t have that.
^^ correct, its to heat it up faster so it can switch to closed loop quicker.
(for some reason i thought whiteknightVR94 was talking about another connector)
They changed back to the 2 wire o2 sensors on the vt, so your not missing out on much, it actually causes more problems than what it was designed to do
What does cutting this wire do exactly?
Make you o2 sensors work better?
There is a voltage leak from the heater circuit to the signal circuit. If you are experiencing problems with O2 sensor error codes, 99% of the time it will be this. Unless the sensor is actually stuffed.
Some people have successfully rewired the earths straight to the PCM and this fixes it also. But the easy fix is to cut the heater wire.
Thanks for that. I havent had a direct sensor code, except for 64 which means one bank is lean - but that went away.
Would cutting the wire in general make any difference? Regardless of whether or not I have a reading, or its stuffed?
It wouldn't really make any difference if it was working OK. But the 64 could relate to the voltage leak, although it is the RHS that had the problem.
The code went away? You haven't had the PCM set the code since a reset?
nope, only getting code 76 - air fuel ratio bank thing since the reset. Have taken it to a mechanic, he pretty much said it could be this or could be that, which is what I was saying.
I did switch the o2 sensors around, would that have made any difference?
Considering cutting the wire, hoping it might get rid of the hesitation and backfires my car is getting.
i cut the pink wire on both left & right hand sides .
my vs was running rough till it warmed up . couldn't find my thread on it either ....
no great difference in cutting the wire or not , if u have no problems .
+1 sticky = o2 sensor (cut the pink wire)
Hesitating and back firing? Check the purge hose on the bottom of the throttle body. It runs to the back of the manifold, if that has split or broken it will do what yours is doing.
that hose seems ok. I checked all the hoses from the throttle body, fuel lines and the ones going to the charcoal box. everything seems in order.
All of this happend after a degrease with the engine cover on.
You may have dislodged something or gotten water into one of the connectors.
Check the plugs going to the DFI module. Another thing that isn't too common is water could have gotten between the coil pack and DFI module.
Check all the leads too, do you have a multi meter?
Have checked and replaced leads and plugs.
I'm thinking that because the problem has only been since the degrease (Saturday 25th) is probably something I have disloged or killed.
Have taken all the coil packs off, and wd'd, also wd'd the injectors, and the air sensors on both ends, plus whatever sensor's I could reach properly on the engine.
All to no avail.
The plugs on the passenger side where rich, 2 of them smelling a bit like aerostart (which I havent sprayed) and the drivers side plugs where dark in places, but had some white on them - so normal.
Am running out of ideas, and cant afford to take it to a mechanic to spend $400+ on them trying to do the same job as I am, as they have already said they don't really know.
Thanks for your replies, they are really helping to narrow it all down.
