+ Reply to Thread
Results 1 to 11 of 11
Thread: limp home mode...
    roon_VR's Avatar
    roon_VR is offline VR executive Commodore roon_VR Executive
    3.8 V6 executive SII VR
    Mar 2007
    Default limp home mode...
    hello people,
    Just a quick question. If i thrash my car or take off quickly from the lights, the tranny kicks into limp home mode where it shifts quite uncomfortably and tends to not kick into 4th gear. However, i don't get any error codes logged when limp home mode kicks in. Reading from other threads, this is fixed simply by replacing the solenoid, but what i wanted to know is, could limp home mode be a sign of wear and tear on the tranny? Also, there is a 1-2 second delay when i shift the gears from park to drive or reverse. Is this another sign of wear and tear? I plan on doing some towing soon so i just wanted to know if a shift kit would be recommended. I don't want to install a shift kit if these issues are a sign of wear and tear.
    Thanks,
    My car audio:
    CD tuner: Alpine CDA-9884E with Ipod interface
    Front speakers: Alpine Type R SPR-17S 6.5 component speakers, powered by a avant-garde 23dxi 2 channel amplifier - 2x51 watt RMS
    Rear speakers: pioneer coaxials connected to tuner
    Subwoofer: Alpine Type R SWR-1222D 12" 2 ohm dual voice coil 500 watts RMS powered by a response precision 2x150 watts RMS 2 channel amp bridged to 500 watts RMS @ 4 ohms
    hako is offline Donating Member hako Senator hako Senator hako Senator
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'm no expert so take my words with a pinch of salt but, if your car is going into Limp Home Mode then you have a problem. LHM can be activated by a number of different faults and the solenoids are only one of them.
    I'd think twice about installing a shift kit if I wanted to do serious towing as its recognised that a shift kit can bring on transmission failure earlier than normal....probably because with the kit you will drive "differently". Towing is about "nice and easy" so the idea is to reduce any stresses on the transmission to a minimum so that the trans can cope with the extra loads.
    Maybe your problem is simply that the transmission is low on fluid....if not then do a service on it....check the colour of the fluid - if red then OK...if brown then check bank balance. Good Luck.
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    just thought id mention, whilst in limp home mode the trans wouldnt be shifting at all (you mention it shifts uncomfortable during limp home mode) so that might not be whats actually happening.
    the only gear available in limp home mode is 3rd, which makes taking off from standing starts and inclines at low speed exceptionally annoying.
    also, a small delay between shifting from gear to neutral or reverse is normal.
    Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
    VS L67 Statesman
    Oct 2006
    Melbourne, VIC
    Quote Originally Posted by roon_VR View Post
    hello people,
    Thanks,
    I've got a rebuilt/toughened auto in my car, and it will go into Limp Home mode if I do naughty things :P. All I have to do is turn the car off and start it back up and it's all good again.
    So LHM isn't a sign of wear and tear. It's just the computer trying to stop you from doing any damage to the engine/transmission.
    roon_VR's Avatar
    Mar 2007
    Quote Originally Posted by Thomas1 View Post
    well that's what i do as well. I turn off the engine, have a cigarette and then turn the car back on and it's back to normal so I'm assuming it is limp home mode.
    My car audio:
    HoldenManDan's Avatar
    HoldenManDan is offline Built, not bought... HoldenManDan Calais
    VS Exec SII 4.2L L67 T56 :D
    Jul 2006
    Penrith, NSW
    hey man, im no pro with autos but i'm getting there... from what i've gathered, if its a longer than normal delay between P R and D then that means it's time for a rebuild, thats what you'll probably wanna do before you go towing things.
    And LHM is engaged because a problem has been detected, not to stop you from thrashing it. So if it does engage, its because a problem has developed, not because the PCM wants you to stop hooning lol.
    Hope this helps
    Factory 5 speed VSII, now 4.2 Litre L67 with T56 6 speed
    roon_VR's Avatar
    Mar 2007
    Quote Originally Posted by HoldenManDan View Post
    Hope this helps
    its not a huge delay, its only between 1-2 second delay in between P,R and D. It still shifts smoothly when the engine is cold so i think there's still some life in it.
    My car audio:
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Trouble is they fail at the worst times. Mine failed when I was 1400km from home and 200km from the nearest auto place. May pay to carry a rabbits foot.
    DannyboyDS is offline Just hand me the pliers. DannyboyDS Monaro DannyboyDS Monaro
    VS Berlina
    Feb 2007
    1-2 seconds is meant to be normal.
    having to shut down and wait a few minutes indicates your trans is overheating.
    VRII Executive V6
    May 2008
    what the **** is limp home mode???? i have never heard of this!!!! could poeple please tell me more about what this is and what it does i would like to know...
    thanks
    roon_VR's Avatar
    Mar 2007
    Quote Originally Posted by KeepItStock View Post
    thanks
    Limp home mode@Everything2.com
    My car audio:
+ Reply to Thread
  1. Limp Mode
    By martrogers in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-10-2007, 07:18 AM
  2. stuck in limp home mode
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-12-2006, 10:17 PM
  3. limp home mode
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-07-2006, 03:56 AM
  4. limp home mode
    Last Post: 24-11-2005, 09:17 AM
  5. ecu still in limp mode
    By Juzzy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-09-2005, 03:51 PM
