Results 1 to 14 of 14
Thread: 1995 vs commodore keeps stopping
    Mar 2008
    Default 1995 vs commodore keeps stopping
    1995 vs commodore keeps stopping runs perfect but when you drive it will suddenly stop the engine that is runs perfect .
    it is just like you have turned the key off but haveent touched the key will start perfectly again hope you understand what i mean
    you will be driving along the engine stops (no coughing or farting runs perfect)then suddenly the enginr stops when you go 2 start engine after it stops starts perfect runs like a dream.
    ????????????????????helppppppppppppppppppppppppppp p
    7 snakes 4 kids 1 wife 1 ea falcon 1 vs dunny door
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    When it just stops like that and starts first kick - I'd start with the ECU. If you know someone that has a VS do a swap for a while. See how that goes.
    The CAS will normally (when on it's last leg) will need to cool a little before starting. The coils/DFI unit can also be at the root of the problem. This is normally a bit of a miss fire to start with and tends to go dead.
    and 3 Dangerous non ABS VN's
    Mar 2008
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    Quote Originally Posted by carpetsnake View Post
    the more info the better mate. does it stall only during driving (as in moving under throttle - or off throttle) or only whilst stationary at idle?
    is it hesitant to move from a stationary point when you try accelerate - like there's a flat spot there?
    does it idle ok? what sort of rpm does it idle at and is it smooth (constant rpm, not moving up and down)?
    when it stalls, are you using alot of power? radio/cd, headlights, wipers, etc.
    there's a few things it's likely to be, but with more info it helps narrow it down.
    Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
    Mar 2008
    answers to sircruisealotVS
    when driving under throttle stalls
    ,no flat spots,
    takes off fine no flat spots at any rpms
    not using much power only radio
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    I had the same problem Mate just get the CAS changed common problem. That was nearly a year ago all good.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    Mar 2008
    had the cas done all fine now
    VS_Pete_1's Avatar
    Dec 2007
    Sweet mate
    vs commodore berlina
    May 2009
    ello. Well proud owner of 96 C'dore Berlina with just 40000ks on it . MINT cond!!. The car has obsoleted all self taught mechanical knowledge. (upgraded from HJ that had for 19 years). Car has twice shown all warning lights and let me drive home on battery. But then won't start. Can jump-start from booster, and no lights come on on dashboard, runs perfect. Then it happened again today, with 3 kids in the rain!. have checked battery all good, checked charge circuit ; all good. WHY is this happening: hoping fo a simple answer!!??
    vs2 berlina 96 3.8 auto hsv plated
    Sep 2008
    brisbane nth
    This may be my problem ?
    Symptoms...
    When cruise is on, there is a miss fire, & sometimes the motor just cuts out. Other times the motor wont start. During the cranking while trying to start it again, the red security light on the radio blinks. While the red light blinks, it wont start. Once the light stops blinking, it starts.
    Can hear the fuel pump start up while this is happening. So I can rule that out.
    How much am I looking at to have the CAS changed ?
    Kind Rgds
    Dave
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Sounds more like a security/immobiliser problem. Try pressing the unlock button when the key is in the keyhole and the red blinking light should go out....also check that the metal ring around the keyhole is making contact with the metal knob on the keyhead when the key is inserted (this passes the security code and makes the red light go out...as does pressing the unlock button)
    Good luck.
    Vs wagon
    Mar 2010
    south yarra
    thread dig
  1. 1995 VS Commodore Acclaim
    By Billo55 in forum Vehicles For Sale
    Last Post: 27-10-2008, 09:45 AM
  2. FS: 1995 VS Commodore (manual) [ebay]
    By yods in forum Parts And Other Items For Sale
    Last Post: 20-05-2008, 07:26 PM
  3. For Sale in TAS : 1995 model Commodore S
    By proto_vr in forum Vehicles For Sale
    Last Post: 14-03-2007, 10:08 AM
  4. F/S [QLD] 1995 VS Commodore Executive
    By Infus10n in forum Parts And Other Items For Sale
    Last Post: 09-07-2006, 01:10 AM
  5. My 1995 VS Commodore - [For Sale]
    By Infus10n in forum VR - VS
    Last Post: 25-05-2006, 05:49 PM
