Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: VS V6 O2 sensors??????????????
    pando666 is offline milk comes in 2 litres
    vs exec
    Jul 2008
    sydney
    Default VS V6 O2 sensors??????????????
    Just a few things,
    *How much do they cost?.Both GMH and aftermarket?.
    *Are there good and bad quality one?.
    *Are they both the same?.(L and R wiring plug etc)
    *Are any special tools needed to fit them?.
    *Are they hard to fit?.
    *Are there any questions I've missed?.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by pando666 View Post
    Just a few things,
    *How much do they cost?.Both GMH and aftermarket?. Around $50-$70
    *Are there good and bad quality one?. Not really
    *Are they both the same?.(L and R wiring plug etc) Yes
    *Are any special tools needed to fit them?. No, just a 22mm spanner. (I think)
    *Are they hard to fit?. No, unplug it, undo it, fit new one.
    *Are there any questions I've missed?. Don't bother trying to clean them, the sensor is inside the metal case. You can't clean them.
    Visit my Facebook page
    Quote Originally Posted by 191kieran191 View Post
    contact Not an abba fan he is the best
    Nuff said really.
    1999 VTII SENATOR
    YOU BUY!!!
    ALL SERIOUS OFFERS CONSIDERED
    http://www.carsales.com.au/private/d...o=Stock&items=[Make:HSV,Model:SENATOR,Series:VT%20II]&sort=default
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    GM around $90-120, aftermarket $50-70
    Go GM, there are 2 types, wide band and narrow band, dont know which on the VS
    yes both are the same, VS are a 4 wire O2 sensor (2 for heater, 2 for O2)
    Just an open spanner, think its 17mm
    Just like a normal bolt, unscrews out and new one screws in
    Drivers side one can be accessed from behind the front wheel, Passengers side can be access via engine bay.
    location of both O2 sensors may vary depending on exhaust being standard or aftermarket.
    I think thats about it
    EDIT: NAAF, bet me too it!!
    vs exec
    Jul 2008
    sydney
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Hehe...too quick.
    Narrow band is what is most common. Wide band is more for specialist applications. 90% of cars use narrow band.
    Nuff said really.
    1999 VTII SENATOR
    YOU BUY!!!
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    but if there cloged up with gunk can they just lightly cleaned with a soft brush? i know you wont be able to get to teh sesor its self....also i have cleaned the one on my vn before buy useing compressed air.....a heap of **** came out and now it runs alot better
    cheers
    Dan VS 231's Avatar
    Dan VS 231 is offline Ell Sixty Seven
    VY Calais L67
    Jun 2008
    Perth W.A.
    Ok heres another question that I think may have been answered before but it seems relevant here. Im getting some pacemakers for my 6 and was wanting to know if the 02 sensors are in the same rough location on the pace's and if new gmh ones would fit the same or would I need some aftermarket types? Because I am going to get new 02 sensors regardless when the system gets put in. Cheers.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Yes, they are in the same place, roughly. And yes, whether you get genuine or aftermarket, they will still fit.
    Nuff said really.
    1999 VTII SENATOR
    YOU BUY!!!
    vs exec
    Jul 2008
    sydney
    st3r3otyp3's Avatar
    st3r3otyp3 is online now undar8 me
    2 VXII V8 dailys
    Feb 2008
    katanning W.A
    Is Delphi genuine holden brand?
    No, I think only AC DELCO is in this case.
    ignorance is bliss.
    Holden VS Executive Sedan
    Apr 2009
    Blacktown
    vt s s1
    Mar 2009
    Once you get under the car you will clearly see them, theyld be sticking out the manifold.
    The Bolt is 22mm and before undoing spray a bit of rust off and make sure you get the spanner on sqaure so you dont round it.
    Dam those prices are cheap i just paid 90bucks for a GM one for my VT and that was cost, they reatiled at $180
    Apr 2009
    Blacktown
    yeah cause i think one of them is full of crap, and needs to be cleaned out
    Tit-Tit-Titian™
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    AC Delco are the genuine Holden ones. Usually the aftermarket ones you have to wire and solder in, the Delco ones you just unplug the old one, and plug in the new one.
    You pay a few bucks extra for the genuine ones (maybe like $20), but it's alot easier.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
  15. #15
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    if its full of crap its stuffed fit a new one
  16. #16
    Apr 2009
    Blacktown
  17. #17
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    No. New one. Don't clean the old one. They really cost **** all for how long they last.
  18. #18
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    '12 Pusslux - Daily, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by Cobez View Post
    The Delphi ones are a direct swap aswell.
    Also a few more notes about oxygen sensors.
    Its a 22mm spanner you need to swap them out, warm the car up first, but be careful not to burn yourself on the hot exhaust, but it makes it easier for them to come out.
    Genuine are $88.50 from Holden, I got Delphi ones off ebay for 58 each, so saves $30.50 each, total of saving of $61 bux. So far Delphi is working fine.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
  19. #19
    Apr 2009
    Blacktown
    wow its amazing how much holden will try to f#ck you up the arse with money
    Tit-Tit-Titian™
  20. #20
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    About 6 months ago I bought some genuine O2's from holden and the ones they gave me were Vs ones exactly like they used 10 years ago (4 generations old in O2 sensors). and they cost me about $60 ea trade but my problem which wasn't the O2's F*#@ed them up so I bought another 2 from my local store and got Nippon Denso's which were exactly like my VZ factory ones, the current style and they worked perfect straight away. and only cost $45 each.
    So be careful with Holden because you could just be getting old shelf stock as the early ones are no longer available anywhere else.
  21. #21
    E46 M3
    Jun 2009
    Quote Originally Posted by ephect View Post
    not all vs' are 4 wire, some are 2 wire. jump under ya car and see what you got
  22. #22
    Swordsy's Avatar
    Swordsy is offline mmmm beer....
    VUII Maloo R8 - XJR1200 - XR450R
    Nov 2007
    Newi NSW
    Quote Originally Posted by rocco555 View Post
    My Old VS was a 2 wire (ecotec)
  23. #23
    Apr 2009
    Blacktown
    i found oxygen sensor, wat a pain in the arse thing, and holden wat to charge me 108 dollars for one, anyone know where to get cheaper ones in blacktown location
    Tit-Tit-Titian™
  24. #24
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    yea im suprised this wasnt picked up on, there was a heap of threads around this time, and i'd leant a few threads in that the early ones where 2 wire.
  25. #25
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    o2 sensors operate strictly on heat yeah? they are a thermometer technically, I would take a punt and say greater heat increases circuit resistance?
    and this is why cleaning them really wont do allot and why the sensor itself is actually incased within metal?
    How do some silicones stuff them up though?
  1. S2 VY O2 Sensors
    By batemada in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-09-2007, 01:13 PM
  2. o2 sensors
    By impulsesv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-09-2007, 06:42 PM
  3. O2 Sensors how many
    By miedwards in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-07-2006, 01:54 AM
  4. sensors
    By CAFA_TF in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-04-2005, 08:20 AM
  5. O2 sensors...
    By MY_95_VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-03-2005, 03:58 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
