+ Reply to Thread
Results 1 to 7 of 7
Thread: ttc solinoid
    VR Statesman
    Oct 2007
    Default ttc solinoid
    Hey does anyone know what the tcc solinoid is?
    VS Acclaim V6
    Jul 2006
    Its the Torque Convertor lockup solenoid, its meant to lock the torque convertor when cruising generally round 80 clicks she'll lock and unlock when u throttle it.
    did u get an error code about it?
    hako is offline Donating Member hako Senator hako Senator hako Senator
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The TCC lock up solenoid operates to lock the torque converter solid at cruising speeds. This allows the auto to give similar economy to a manual transmission.
    LowVp's Avatar
    LowVp is offline VP nut LowVp Executive
    VP Ute 3.8T M5
    Aug 2005
    Ipswich, Qld
    located in the pump in the nose of the box has to be removed to remove the pump itself
    VR Statesman
    Oct 2007
    i ha the code come up.. its gone now... one other thing when im driving when i back off it does hold in the gear it just drops the revs to idle and continues crusing liike its in neutral.
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru Not_An_Abba_Fan W427 Not_An_Abba_Fan W427 Not_An_Abba_Fan W427 Not_An_Abba_Fan W427
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    It seems to be working then. Reset the PCM and check the codes again after a few days. It may have been sticky and not locked up when the PCM told it to.
    http://www.facebook.com/?ref=home#!/...21292461287296
    Chris_vr's Avatar
    Chris_vr is offline HVY-MTL Chris_vr Executive
    VR Executive
    Feb 2009
    Quote Originally Posted by ST.47.ES View Post
    This is exactly what I'm getting to, and I do get the error code. Sometimes it works fine but only for about 15 minutes. But I also get TPS - Low VOltage. Do I need to replace TPS and TCC Solenoid???
    *Not trying to hijack a thread, just getting the same issues
+ Reply to Thread
  1. starter motor solinoid stuck
    By Lowwwerd vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2010, 12:34 PM
  2. Air solinoid pack help
    By Bongo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2006, 06:45 PM
